Schematic diagram z506
Fuse always busted
Aurex sb130
The fuse is blowing due to a short in either the power supply or more likely the main amp. Very often caused by the device or devices fixed to the heat sink.
Mar 04, 2014 | Audio Players & Recorders
Always busted the fuse
If keeps blowing fuse either wrong fuse (some are special types) or a short somewhere in the set--check the power supply first.
Apr 18, 2012 | Hitachi Televison & Video
Shredder does not power on
Good day!!!!
please try to check the plug if it is OK..
Then look for the fuse if busted...
If the fuse is busted look at the fuse if only disconnect the wire inside so that you can determine the cause of blowing of fuse..if the fuse is dark or have color black inside your machine have a short circuit..if not got fluctuate high current in split second (that is normal)..just replaced the fuse with the same type and ratings..
If the fuse always blows after power ON your machine need further repair it have short circuit..
Thanks for using fixya...
Aug 10, 2011 | Vacuums
Always drain of battery solution and busted all bulb?
most likely simply the fuse is to large. check your fuse should be an inline fuse next to the battery.
Feb 06, 2011 | 2001 kawasaki KMX 125
In first channel always blowing the fuse or other
The fuse blows because one of the parts in the amp section is acting as if it was just a piece of wire and not a semiconductor at all. Check out any parts on the heat sink first. If they are transistors you can put an Ohm meter on the pins and if it gives a reading as though you had just touched the two probes together, you have the bad part.
Feb 21, 2010 | Audio Players & Recorders
The fuse of my fan always gets busted even high ampheres
Which fan are we talking about the radiator fan or interior air recirculating fan??
Irrespective which fan, there is a problem with the fan wiring / motor drawing excess current.
Dec 01, 2009 | Nissan GT-R Cars & Trucks
Fuse on a/c always gets busted after a few minutes
YOUR COMPRESSOR CLUTCH IS LOCKING UP AND BLOWING THE FUSE. IT NEEDS TO BE REPLACED, EITHER THE CLUTCH OR THE WHOLE COMPRESSOR. SORRY FOR THE BAD NEWS. HOPE THIS SOLVES THE PROBLEM. GOOD LUCK
Apr 30, 2009 | 2004 Audi A4
804 people viewed this question
 Grubhead
Grubhead
