Question about GE Profile JVB67HWW 36" Telescopic Downdraft Ventilation System: White on White Kitchen Hood
Downdraft vent won't raise...
I pushed the button to lower it but there was an obstruction. I tried pushing the button to raise it, but it wouldn't raise back up so I pulled the obstruction out of the way and the vent went down kind of hard. It doesn't look like it is on it's track or something. Once down the motor just kept running but it wouldn't raise back up. We disconnected it for now, but can we fix it?
2 Suggested Answers
SOURCE: I have a GE downdraft
I had the same problem. It is the switch. Hang on because that little $3 swtich is about $60 from a parts house. Sears wanted $114. If you take the switch out or disconnect the switch at the board and jumper the two leads, (12v), it should work fine. That will tell you whether it is the switch. I did it with a small screwdriver. Careful, even though it is 12v it will get yor attention. I have all GE appliances and they are all junk.
Posted on Nov 07, 2010
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
Can't raise outboard motor up so I can trailer it
Disconnect Battery! Just For Safety.Try Turning Prop And Engage Forward Gear, Once In Gear Try Lifting Motor!!
Mar 09, 2013 | Boating
Can't print due to E displayed. I already pushed the reset button on back of machine and it did not remove the E
The same thing happened to me. Wouldn't feed paper and the printer function didn't work. The E was in the lower left of the screen. I took the ink cartridge out and reseated it and that fixed the problem. It was installed incorrectly direct from the factory as my calculator was new out of the box.
Mar 08, 2012 | Canon P23-DHV Calculator
I have a brand new Dyson DC28 Airmuscle Vacuumand it is so hard to push and/or pull. Is there a button to make it easier or is it the machine?
Your DC28 is equipped with Airmuscle™ technology, which allows you to raise or lower the brushbar to suit the flooring you're trying to clean. You should be able to make your DC28 easier to push by changing the setting of the carpet height selector. You can find out how to adjust this in the user guide included with the cleaner. In case you don't have yours to hand, here's an online copy:
http://media.dyson.com/downloads/US/floorcare/Manuals/dc28_opmanual_usa.pdf
By raising the brushbar, you should be able to reduce the force needed to push and pull the cleaner. If you've tried this, it may simply be the powerful suction which is making it feel a little heavy to use.
If you're still concerned, please get in touch with us free on 1866MYDYSON or email askdysonUS@dyson.com. One of our experts will be happy to answer your questions.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
I have a GE downdraft vent, model #JVB94SH1SS. A couple months ago I pushed the button to put it down and it went down and up and down and up and down and up and...well you get it. I had to unplug it to...
Oct 01, 2010 | GE Profile JVB67HWW 36" Telescopic...
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
