Ariston aqxxl 109 8kg
Retaining wire/spring has rusted out and the washer is leaking out he bottom of the door on the washing machine. Where can I find a replacement hoop with new spring. I've looked at lots of parts and can't find the ring and spring- the rubber gasket does not need replacing
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Posted on Jun 05, 2008
barkencoa
  • 3463 Answers
SOURCE: front load washing machine rubber
What make and model is your washer?
Posted on Nov 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Door gasket damaged
Have you sorted your problem out yet?
You can get any spares you need by going on line to:www.hotpoint.co.uk, and followning the links.
Good luck.
Posted on Dec 02, 2008
barkencoa
  • 3463 Answers
SOURCE: replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Thanks.
Posted on Dec 19, 2008
  • 157 Answers
SOURCE: BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Posted on Jun 30, 2009
Washing machine won't take enough water and won't take washing powder and leaves bad smell inside
AH yes front loaders are bad about this type problem .change the detergent to liquid and run a coulpe empty wash cycles with bleach and or baking soda
Mar 21, 2015 | Ariston Technologies Washing Machines
I have an ariston aqualtis AQXXL washing machine and the door will not close. The lock is jammed. I tried to lower the lock manually but it still doesn't open. How do i unlock it?
turn the power off at the mains
take the top off and try to do it from behind
the interlock may have jammed up and youll prob need to fiddle with it a bit
pushing the door in a little will make it easier to move the locking key from behind
then youll need a new door interlock
Mar 02, 2015 | Washing Machines
How to remove front of Ariston washing machine AVD 129 SK
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Mar 18, 2014 | Ariston Technologies Washing Machines
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
Machine flashes F then dl. What can we do?
There's a fault detected with the door lock and switch assembly. The door lock is not working or the door lock switch is not activated. This indicates that the door lock and switch assembly is malfunctioning and needs to be replaced to address the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Using needle nose pliers, start where the spring and wire are connected and pull the wire out of the groove of the door gasket.
Remove the three screws securing the door lock and switch assembly to the front panel.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Slightly lift the door lock and switch assembly then pull it back off the front panel and out of the cabinet.
Transfer the wiring harnesses to the new door lock and switch assembly one at a time then install it in place behind the front panel. Secure the
door lock and switch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Install the retaining hoop with the spring positioned at the bottom of the door gasket.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks during spin cycle. my daughter pulled the drum out of alignment temporarily while pulling a comforter out of the washer. the door seal is intact although there is a wire ring that came out...
The spring goes around the door seal it needs to be stretched around the small lip that holds the seal in place. The spring is where you grab it with needle nose pliers. the spring goes on the bottom. You will see where the rubber seal has a wider spot this is where the spring should be right at the 6 o'clock position. This is a little tricky to do the first time trying but keep at it you will get it.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
The wire around the rubber seal on my bosch washer
This video will show you how to change a door seal on this Bosch WFMC2100UC washing machine
Jan 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Aug 27, 2008 | Ariston Technologies AWD120 13 lb. Washer...
My washing machine is leaking water everywhere when rinsing
you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
let me know if that helped at all
zac
Apr 20, 2008 | Ariston Technologies AWD121WH
Washing Machines Logo
Top Washing Machines Experts
