Question about Peavey Valveking Vk100 Guitar Head
Peavey vk100 clean channel and lead channel low volume
Just replaced the power tubes with four sovtek 6l6wxt tubes, and the clean and lead channels are so quiet at 9 on the volume dial it sounds like a 15watt practice amp. However, when the gain button is pushed in I get my normal distortion volume whether it is in clean or lead. I`m only getting the right volume with the gain button active. Does anyone know what could be causing this?
3 Suggested Answers
  • 5603 Answers
SOURCE: My Peavey vk100 head is
You may simply be overdriving the clean channel and causing it to "flat top" . See if it occurs when you back the gain down a bit. New tubes PROBABLY will not help and be a waste of money. You may be unconciously playing harder during the popping episodes. You cannot hear level variations smaller than about 3 Db BUT the electronics will sense much smaller variations. You could gently tap the tubes with a lead pencil to listen for any pops... NOTE: tubes can be slightly microphonic so some sound from tapping is normal.
Yes, a cable can be noisy and not show itself when using intentio0nal distoprtion... try another to verify it is not the problem.
Posted on Jan 02, 2011
  • 52 Answers
SOURCE: Wires to main speaker are, Yellow & Blue
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Posted on Feb 21, 2011
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey bandit 112
have you tried using a foot pedal? Are you sure it is switching (green light turns red, etc?). On the lead channel are you turning up the gain all the way and the volume down?
Oct 12, 2013 | Music
My Marshall AVT150H has low output.
How do the pots sound? any stactic on the volume pots ? may need replacing or cleaning them if so . I would also consider replacing the tube
Jan 29, 2013 | Music
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Power problems with my Peavey PV-1500
Suspect that the pot is broken, or start cleaning all the back switches, this pv amps suffer from a terrible switch quality.
Mar 15, 2012 | Peavey Electronics Peavey Pv 1500 Power...
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have a Peavey ValveKing 112. It seems like it just takes forever for the tubes to warm up. For like the first hour that it's turned on the clean channel seems fine, but the second channel doesn't work....
Buy ONE new 12AX7 and try it in location V1 and if it doesn't help, try it in V2. This tube has TWO heaters in it and if one is intermittent that could cause your problem. The vibration MIGHT be "fixing" a briken heater after some time.
There are MANY components that could cause this, so you might have to take it in for repair if it isn't a simple tube problem. Since it works on the clean channel, V3 should be OK.
Feb 11, 2011 | Peavey Valveking 112 - Tube Guitar...
My Peavey vk100 head is running through a Carvin Legacy 2x12 cab. On the clean channel there is an inconsistent popping sound. It will happen loudly for a few seconds, and then not at all for a while, and...
Jan 02, 2011 | Peavey Valveking Vk100 Guitar Head
Peavey Valveking Vk100 Guitar Head Logo
64 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
