Question about Crafts & Hobbies
Press drying flowers
How do I press dry flowers? Trying to make bookmarks.
    New Friend:
I love the Microfleur flower press. It uses your microwave to remove water from flowers, leaves, and botanical specimens so they can be added to your project the same day. I keep them dry by layering them with silica crystals. http://www.microfleur.com/
Posted on Nov 14, 2014
Testimonial: "That looks really cool! I might just order one. Thanks!"
    New Friend:
What you can do is put the flower between two pieces of tissue paper in a heavy book and microwave the book for about thirty seconds at a time until done.
Posted on Apr 30, 2013
What do you do when the flower on a bromeliad dries up but the leaves are beautiful
Remove the dried up flower. Keep the care going, in the space of a few weeks/ months look out for more flowers, or even try asking on Google.
Dec 29, 2017 | Garden
Can you add a bookmark?
How to use the GoGear bookmark feature in Audio books:
Adding a bookmark
  • During play, press "Option" button.
  • Select "Bookmark".
  • Select "Add bookmark".
  • Press "Play" button to save bookmark.
Accessing a Bookmark
  • Select "Go to bookmark".
  • Select bookmark from the list you want.
  • Press "Play" button to play the selected bookmark.
Removing a Bookmark
  • Select "Delete bookmark".
  • Press "Play" button to delete the selected bookmark.
Oct 10, 2013 | Philips Gogear SA2RGA04KS Mp3 Video Player
Drying out flowers to make a bookmark with contact paper.
you can keep them in the book for a bit to flatten them. They will not dry very fast in there. after they are sufficently flattened take them out of the book to dry better.
May 01, 2013 | Cameras
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
When clothes are dryed on the perm press cycle either reg dry or very dry, they are still damp. I have to run it through 2 or more times to get them dry. I'm told by Bosch that is what perm press is...then...
You may not be getting sufficient air flow--remove the lint filter and wash it with detergent and hot water. Also clean excessive lint out of the air vents (under the filter too). Don't use 'perm press' if you want things absolutely dry. Remove and hang up before they cool. 'Damp dry' really means 'don't dry' I guess!
Aug 28, 2009 | Dryers
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Water entered into my motorola v3i and power off automatically when i switched on and press the key pad.nothing functioning give me a solution please
you need to dry this guy out...
pull the battery and leave out... that will minimize electronic damage... if at all possible.
Purchase a container of silica crystals at a nearby hobby/crafts supply store (used to dry flowers).
put the phone and the open container of silica into a ziploc bag and let it draw the moisture out of your phone.
let it be for a few days...
No guarantees, but it could get you back up again.
K
Jul 02, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Dishwarsher
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Cant use dryer
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Feb 17, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Crafts & Hobbies Logo
732 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
