Question about Kenmore 75050 Wall/Window Air Conditioner
All that foam packing inside Kenmore 75050 air conditioner
Husband and adult son who are pretty handy but stumped by all the foam packing inside unit. Instructions don't say a thing about it. help
Re: all that foam packing inside Kenmore 75050 air...
Make sure what you're calling foam packing is not in reality foam insulation. If that's the case you'll ruin your unit by removing it. It would be pretty unusual for packing to be placed inside the unit.
Posted on Aug 12, 2007
0 characters
3 Points
Its suppose to have some styro foam inside? or its suppose to be out?
Most window A/C units have styrofoam lining the air vent. Unless the manual says to remove a piece of foam when unpacking the unit, leave it there.
Jul 30, 2012 | Kenmore Model 253.70181 Window Air...
Can the styrofoam insulation in our air conditioner be replaced or patched?
Yes it can but you will have to use expandable foam. You must shape it after it drys. Old trick, works like a charm. Should be an under $5 repair
May 29, 2012 | Whirlpool ACQ158XP Wall/Window Air...
I can't find one this model replaced model 74054 purchased in 6/10/93 thank you
Your message was a little confusing. But, if you're looking for the Kenmore 75050 Thru-Wall/Window AC, you can find it at Sears online at the following link.
Hope this helped you find the model you wanted. Please let me know. Thanks.
Jun 09, 2011 | Kenmore 75050 Wall/Window Air Conditioner
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
My kenmore window unit keeps blowing reset button what could be problem. its not the plug to house i already checked it
It's the reset button on the plug itself.
Those things are the worst invention ever.
Cut that thing off and attach a normal plug.
Then buy a cheap power strip with automatic reset switch and plug to that.
Mar 11, 2010 | Kenmore 75050 Wall/Window Air Conditioner
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Sep 06, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Leaking water
we had the same issue, and it turned out that our filters inside the unit (the indoor unit) were pretty dirty and needed a clean, and also the run-off pipe/hose was blocked with a sludge, etc. We had to clean the filters inside just with warm soapy water and then blow up the hose outside and it fixed it pretty much straight away.
handy tip - take your mouth off the hose quickly, as the sludge will come out of there pretty quickly as the handy one found out!
Aug 18, 2008 | Fujitsu 18C1 Air Conditioner
Kenmore ac blowing black peices all over room.
that is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
May 10, 2008 | Kenmore 70088 Air Conditioner
Kenmore aircondition
First is to make sure the evap and condenser coils are very clean. A dirty evap coil will cause icing as well as a blower not running and low freon. Hope this helps. Thx RepairUSA
Aug 31, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Leaking water
You AC should drip water from the rear this is normal it should be tilted to the rear. I don't know about the odd sound..what does it sound like? let me know
Aug 23, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Kenmore 75050 Wall/Window Air Conditioner Logo
157 people viewed this question
Top Kenmore Air Conditioners Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Kenmore Air Conditioner Expert? Answer questions, earn points and help others
