Question about Garden
Bolt size that holds blade on a 173cc yardman push Lawnmore
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Its a 3/8 bolt
Posted on Jun 07, 2014
5 Suggested Answers
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 67 Answers
SOURCE: yardman 173cc wont stay running as long as you
the jet in the carb sounds like it is clogged
Posted on Sep 02, 2009
kel1guy2002
  • 3740 Answers
SOURCE: need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Posted on Apr 27, 2010
vincob
  • 718 Answers
SOURCE: i have a yardman 173cc
If you store this machine outdoors than you might have a little water in the system, otherwise give the carb a good cleaning.
Posted on Nov 09, 2010
BRIGGS 140 CC PUSH MOWER STARTS AND THEN DIES AFTER 4 SECONDS.
if it starts it is getting spark so it has to be in fuel delivery check fuel filter if it is ok rebuild and clean carburator
Jun 29, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Were can i get the manual for yard machine 173cc 11A-41MY229
go to mtdparts.com
under the support folder you will find operator manuals click it
enter your model number where prompted
download the pdf file. and thats it
Mar 13, 2013 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How do you adjust throttle cable on yardman push mower
If there is excess slack in the throttle cable, you can do 1 of 2 things. Either replace the cable, as over time it gets stretched out. Or you can look by the throttle and you should be able to slightly screw out the set screw and take a little slack out and then tighten the screw back up. If there is anything more I can do, let me know. Thanks.
Jun 25, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Where is fuel filter on yardman lawn mower
they only have a screen inside the tank and don't use a regular filter
May 19, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Pullcord wont pull out to srart engin
ok. 1. you are not pulling hard enough,or the turning of the motor is jammed or seized. look under mower deck for an object jammed w/the blade and deck.
Apr 24, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Have a 21" yard man 173cc power push mower high rear wheel
they probably do make them but will be expensive check SearsPartsDirect.com
Nov 29, 2011 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Is the blade take off on a walmart yardman mower clockwise or counterclockwise? I dont want to snap a bolt off.
To remove it you need to turn it counterclockwise...place a block of wood between the blade and the mower to hold the blade, so that you do not need to hold the sharp part of the blade with your hand...
heatman101
Jun 30, 2011 | Sport & Outdoor - Others
The blades are stuck on
Apply some GOOD rust penetrating oil, like PB Blaster or Liquid Wrench to the affected area. Let the penetrant do it's work by allowing it to soak into the parts. 24 hours is long enough. A pre-cleaning with a stiff steel wire brush is recommended though, so the penetrating oil can work better.
Some people heat rusted parts after treating them to break them loose. Most mower blades are installed on a blade adapter that slides onto the bottom of the crankshaft of the mower. Try NOT to round off the heads of the blade bolts. Patience is the key. Impact sockets may have to be used on the bolts if they are extremely stubborn. Use tools that offer absolutely no slack or play in them when put on the blade bolts.
Jun 04, 2011 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Open Questions:
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
