Question about Poulan Pro " Pro" Self Propelled Mower
Poulan pro 550 self propelled, front tires will not disengage, cable is fine, any help?
ken_howard
  • 10 Answers
SOURCE: starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Posted on Apr 25, 2009
rtpflh
  • 546 Answers
SOURCE: where is the oil drain plug
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Posted on Sep 27, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a diagram to assist in changing the drive
IF YOU WOULD POST A MODEL NUMBER FOR THE MACHINE THAT YOU WANT ADVICE FOR, IT WOULD SAVE A LOT OF TIME AND SOMEONE WOULD BE ABLE TO HELP YOU. IF WE HAVE NO IDEA WHAT YOU ARE WORKING ON, WE DON'T KNOW WHAT ADVICE/ASSISTANCE TO OFFER!!!
Posted on Sep 29, 2009
Testimonial: "Thank you for your advise. You just saved me a trip to the repair shop and God only knows how much $$$. Thanks again!!!"
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
  • 302 Answers
SOURCE: where are the oil drain plugs for a poulan pro 550
under the deck above the blade. It is probably a square head pipe plug
Posted on Oct 17, 2009
How to change the oil in my 550 self propelled push mower. Where is the oil plug? How often does the spark plug need to be changed. We've had ours nearly 2 years with lite use, and no maintenance.
There is no drain plug on that model , one has to lift up the entire machine ,tilt and drain the oil out of the filler spout. Change plug once a year - Champion# J19LM
Sep 10, 2011 | Poulan Pro " Pro" Self Propelled Mower
My sister bought a Pro 550. Got a good deal but there was no manual with it. Brand new from Walmart. Was working fine. used it twice. No problems. Boyfriend came by. Said she was suppose to put the whole...
Option #1:If its less than 90 days old return it to walmart.
Option #2: drain the oil and refill with the correct amount. Contact Puolan or a poulan dealer for a manual.
locate the model number and look for your manual here
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/961240002.html
Eric
Jan 19, 2010 | Poulan Pro " Pro" Self Propelled Mower
Where are the oil drain plugs for a poulan pro 550 model
Oct 17, 2009 | Poulan Pro " Pro" Self Propelled Mower
I have a Poulan PRO 550 series that I just bought 4 weeks ago. It won't start. The oil is at a good level. There is plenty of gas. Everything was checked and it still won't start. I am so disappointed. Has...
There are several possibilities for not starting. Water in the gas, Carburetor jet clogged ; Spark plug needs replacing, air filter needs replacing, or you have old gas. Or if you have hit something the flywheel key may be sheared. Hope this helps.
Good day.
Oct 16, 2009 | Poulan Pro " Pro" Self Propelled Mower
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
Engine started smoking real bad, it still starts
Could be just a head gasket, also could be rings. Could also be oil in the gas or bad gas overall. Empty out the gas, change the oil, and try again. If it does the same thing take it to service shop.
Sep 29, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro " Pro" Self Propelled Mower Logo
62 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
