Question about BYTECC BT-ECU2FW Expansion Module
Ecu location for 2005 Kia Amanti
The ECU for 2005 kia Amanti
ECM location in 2005 Kia Amanti. Needing to replace ECM, does anybody have pictures or diagrams of where exactly it is located and how to access it?
2005 Kia Amanti ECM location. Drivers side directly to the right of the Gas Pedal. Remove plastic panel, roll back carpet and you will see it right there.
Dec 06, 2016 | 2005 Kia Amanti
Need repair Manuel for 2005 kia amanti automatic
2005 Kia Amanti Auto Repair Manual - ChiltonDIY
repair.chiltondiy.com/2005/Kia/Amanti/Repair-Manual-Online
Get DIY detailed auto repair information for a 2005 Kia Amanti from the name you trust - Chilton.
Kia Amanti Service, Repair Manual Download - 2004, 2005 ...
? 0:43
https://www.youtube.com/watch?v=N2fvvDE-RAE
Dec 11, 2014 - Uploaded by Steve Davidson
Kia Amanti Service, Repair Manual Download - 2004, 2005, 2006, 2007, ... specifications, neighborhood car parts suppliers portal,auto repair ...
Kia Amanti Repair Manual, Service Manual Online 2004 ...
? 0:43
https://www.youtube.com/watch?v=tT7mnPUstCA
Dec 14, 2014 - Uploaded by Carlos Rivera
Kia Amanti Repair Manual / Service Manual Online - 2004, 2005, 2006, ... Kia owners often struggle to find the right auto repair manual that ...
Jan 19, 2016 | Kia Cars & Trucks
What rims enterchange with a 2005 kia amanti
Kia Amanti Rims & Custom Wheels - CARiD.com
www.carid.com > all products > wheels & tires > custom wheels > Kia
Set your Kia Amanti on the finest chrome rims. Our inventory is the top-notch selection of custom wheels and tires for Kia Amanti from most popular wheel ...
Kia Amanti - Wheel-Size.com
www.wheel-size.com > Makes > Kia
Kia Amanti - Find out the correct alloy wheel fitment, PCD, offset and such specs as bolt pattern, thread size(THD), center bore(CB) for all model years of Kia Amanti. Choose a model year to ... 2009 2008 2007 2006 2005 2004 ยท Kia Amanti l ... Wheel General Info The ranges of possible values for tires and rims of Kia Amanti ...
Buy Wheels and Rims Online for your 2005 KIA AMANTI ...
www.performanceplustire.com > Wheels > KIA > AMANTI
Buy Wheels and Rims Online for your 2005 KIA AMANTI and other custom wheels andrims from PerformancePlusTire.com. PerformancePlusTire.com is one of ..
Oct 25, 2015 | Kia Cars & Trucks
Trouble Code C1604
C1604-ECU Brake System hardware error/fault
Mar 29, 2014 | 2005 Kia Amanti
Where is the flasher fuse for 2005 kia amanti located
Check your owner's manual, the info is in there. If you do not have the manual go to the KIA owner factory site and register the car and then download the manual. We do not have it here.
Sep 09, 2012 | 2005 Kia Amanti
Were is the fuel filter located on 2005 kia amanti
this is a picture showing the fuel filter location. hope help.
Aug 02, 2011 | 2005 Kia Amanti
Check engine light came on at 41000 miles on 2006 kia optima
go to service station for ecu scan, autozone do it free!! here apear what is the problem
Jun 01, 2010 | 2006 Kia Amanti
Kia amanti po441 How do I get this fixed?
P0441 is a standard OBDII code for evap system malfunction - insufficient purge.
the first things to check on your own next time you get a CEL: tighten the gas cap and take care not to top off your tank. A loose gas cap can create an open system, making the ECU think that there's an evap system leak. Topping off can flood the vapor recovery.
Jun 01, 2010 | 2004 Kia Amanti
2005 kia sedona ECU replacement
2005 kia sedona ecu is located on passenger floor under carpet. After you remove the carpet half way, there is a silver plate you have to remove with 10mm deep well socket. there are 4 connector plugs.
Sep 13, 2008 | 2004 Kia Sedona
BYTECC BT-ECU2FW Expansion Module Logo
70 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
indiana650
indiana650
Level 1 Expert
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
