Question about Refrigerators
Door hinge for habco cooler
Door hinge at top of door broken
5 Suggested Answers
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
197jacobs
  • 226 Answers
SOURCE: cooler lid hinge is broken can we replace the
yes. becareful of the sprinng!
Posted on Oct 18, 2010
SOURCE: dometic rm2804 door hinges are worn and plastic
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Posted on Nov 28, 2010
Why won't my hinged cupboard door stay closed?
Depends on type of hinge, If it swings back open after you closed it then either the cupboard is not level (old style hinge)...
Or the spring inside hinge is bad/broken and not holding it closed. If the door opens back just a bit (1/2 inch or so) see if hinge has adjustable screws.
Oct 15, 2016 | Top Knobs Hardware & Accessories
Have a Xerox 3210 workcentre serial no: 5294298012 but the top flap is broken looking for a replacement?
The hinges are available, the part number is 003N01051. http://www.iteminconline.com/itemdesc.asp?ic=003N01051&eq=&Tp=
Aug 28, 2014 | Xerox Office Equipment & Supplies
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
Jun 25, 2009 | Dometic Refrigerators
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
May 02, 2008 | Refrigerators
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
