Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
HELP My Fiance put a plant on top of my Big Screen and it tipped over and some water leaked into the back of the T.V ( not alot, but enough) she then turned the T.V on to see if everything was okay, the T.V turned on, then heard a crackling sound and smelled a odour, and the t.v shut off. As she tryed to turn the t.v back on, the stand by light would come on,the tv would come on for a second, the light would flash 6 times and turn off. Whats going on? Justin
I suggest you sit down for this one! Even a small amount of any liquid on set's internals can reak havoc. What you smelled were components shorting out and possibly burning. Depending on where the water spilled, you may have just one PC board fried, but many circuits are interconnected, which means possible cascade damage to others. Never place plants anything containing liquid on electronic equipment.
Posted on Apr 22, 2008
SOURCE:
Why are spider plant leaves turning yellow & browning on tips of leaves
Yellowing leaves and browned tips, although I am not an expert, seem often to indicate over watering but it is reckoned impossible to over water a spider plant due to the origins of the plant which is a sort of a tropical grass used to warm humid conditions of indirect light..
Perhaps it is being under-watered or positioned in direct light. Water it well each time but allow the soil to dry out between waterings and feed occasionally in the growing season. Misting the leaves might help...
Aug 06, 2018 | Spider Garden
My Scarlet pimpernel Dipladenia sanderil some of the leaves have big brown stains in the middle of the leaves why is that
hi Yvonneduchen.
Blooming mandevillas need moist soil that drains well enough to prevent standing water. Too much water can choke the roots so they don't feed the plant adequately. This can cause the leaves to turn yellow. Conversely, too little water can be deadly, starting with yellow leaves that turn brown and drop off the plant.
or try this link.
Yellow Leaves On Mandevilla Reasons For Yellow Mandevilla Leaves
or this one.
dipladenia leaves turning brown Google Search
Dec 11, 2017 | Washing Machines
I have my tomato plants planted in pots on my patio and the plants don't look like they are growing and the leaves are small and the edges are curling up and are dark in color. What can I do?
you need to give them more room,grow bag is needed when you water use warm water or rain waterrain is best if not warm water grow bag will help if the plant is say 2 inch in a 4ins pot it will take time to grow put 4 or 5 in a big grow bag it will need light and heat don't put in pots
Jun 16, 2017 | Garden
When tomato plants put on green tomatoes. yellow leaves form at bottom with black spot inside. Usually killing plant. can you help?
Might be Tomato Mosaic. Plant should be destroyed as it can spread to other plants. Tobacco on hands can start it off strangely enough. Or could be too much watering at one go, moderate watering about twice a week in dry hot weather, and a little shade while the leaves are still tender. Feed often, but not too strong.
Apr 11, 2017 | Garden
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Sean
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
Not enough memory msg????
there is no problem in ur memory card ur phn memory is full or not enough space perforn themes so delete or move items from phn to memory card and then try again..............
okkkkkk
Feb 02, 2009 | Nokia 5300 Grey Cellular Phone
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
