Question about Honeywell Dolphin 9700
Hard reset how to reboot a dolphin 9700
Honeywell dolphin 6000 cold boot (hard reset)
Factory reset for Honeywell Dolphin 6000
With the pocket off press this combination of keys.
Up volume button, up cursor button, down cursor button and power button.
Then in a green window it will ask for reset all the dispositive by pressing the down cursor button or cancel the action by pressing any other key.
And thats the way of how to reset the Honeywell Dolphin 6000
Mar 15, 2012 | Computers & Internet
I have no mep codes left tried to reboot phone but still not working
Relax, you can reset mep counter back to 10 with cable unlocking at mobile repair shop. This method not only reset mep counter but reset all your blackberry configuration back to default factory setting and can unlock blackberry bold 9700 network to all operator provider so you will not need blackberry unlock code again.
May 05, 2011 | RIM BlackBerry Bold 9700 Smartphone
I try to unlock my Blackberry bold 9700 t-mobile but it shows 0 Attempts Remaining. even if I enter the correct code, phone will still say "Code Error, Please Wait,,,,". I don't know what to do...
if your Blackberry Bold 9700 attempt is finished. you go to local mobile shop. Reboot or flash your blackberry Bold 9700. after this process your Blackberry bold unlock. if you want to unlock your Blackberry. there are so many sites available online to provide Unlock Code for Blackberry Bold 9700. i hope this will help you :)
Mar 07, 2011 | RIM BlackBerry Bold 9700 Smartphone
I cant get my app world to work it just comes up loading all the time ?? please help !
Hard reboot may fix up your problem. Hard reboot means open your phone battery when it is running.
Jan 12, 2011 | RIM BlackBerry Bold 9700 Smartphone
My BB Bold 9700 Does not respond with the soft reset
There are three ways you can reset the black berry phone.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Nov 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
Hi, please help me for APP ERROR 205 RESET BLACKBERRY 9700 THANK'S AZADI
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Oct 05, 2010 | RIM BlackBerry Bold 9700 Smartphone
Blackberry 9700 just shut down and would not reboot . Light turns red. Screen goes to blackberry and as it starts to boot it just stops and will not reboot.
Since it's not possible to do a "wipe", what you could try to do is to soft reset the phone.
Remove the battery while the phone is turning ON, leave the battery out for five minutes, put it back and try to turn it on.
If the same problem occur, contact the manufacturer because the problem has something to do with the software, application, or firmware. The phone needs to be reprogrammed.
Thank you and good luck!
Jul 07, 2010 | RIM BlackBerry Bold 9700 Smartphone
My blackberry bold 9700 has an error message 102. This happened when I rebooted the device after a software upgrade prompted by a blackberry message. How can I sort this out?
Thanks.
Jun 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
I cant turn my blackberry on- it is only booting up half way
my blackberry bold 9700 turns on and boots but keeps restarting by itself
Jun 22, 2010 | RIM BlackBerry Bold Smartphone
Honeywell Dolphin 9700 Logo
32 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
