Question about Kenmore Washing Machines
Kenmore 70 series 20711 washer
Washer will not drain leaving about 2 inches of water in the bottom. Not sure if its spinning or not.
  • 641 Answers
SOURCE: washer water not draining
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely (frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case, check the pump's pulley before you replacing the belt. Let me know if you need for further assistance. Good luck
Posted on Sep 10, 2007
  • 1314 Answers
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Posted on Feb 16, 2008
centurionin
  • 20 Answers
SOURCE: kenmore washer 70 series 20702 will not spin or drain
it sounds like your coupler is broken, with the machine unplugged and with help pull the washer out and then tilt it back. look between the motor and the transmition for a back disk sandwiched between 2 white disks. if it is gone then you need to replace the coupler. it is a medium difficulty job, you need to take the shell off in order to do the job.
Posted on Dec 19, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
duby1990
  • 370 Answers
SOURCE: Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Posted on Feb 13, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
My kenmore series 70 will not spin or drain the water out
open your washer put a screwdriver in the lid switch hole set the machine on spin tell me what happens be careful the tub should spin out the water
Apr 30, 2009 | Kenmore 23822 Top Load Washer
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Kenmore 70 washer will not spin in some washing modes
Has this Washer got a drain water filter ? if so check it first. also some washers have a 'delicates' program which leaves water in the drum to stop creasing, check you manual.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Feb 15, 2008 | Washing Machines
Kenmore top loading washer 70 series
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Dec 10, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
24 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
