Question about Goodman CKL30AR30 Air Conditioner
Model# CDL24-1D fan not moving
Fan is not running. Unit making a noise as if its being pumped up and releasing air.
    Genius:
  • Goodman Master
  • 1,363 Answers
Freon moving through coil makes the noise. change fan relay and capacitor.
Posted on Aug 14, 2015
  • 46 Answers
SOURCE: OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
Posted on May 25, 2009
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
darjr
  • 378 Answers
SOURCE: Goodman model cpe30-1ab heat pump fan not turning.
usually if the fan failed the heater will overheat maybe the smoke you saw was coming from the heater. Let the repairman to repair the fan.
Posted on Jun 08, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
SOURCE: Outside AC unit fan is moving, but no air is blowing out of it
might you have physically installed the fan blade upside down?
Posted on Jun 27, 2009
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
1996 olds aurora runs hot when idling or low speed normal at fast speed what could the problem be
If you have a viscous fan hub The one where the fan spins free on the water pump then the symptom you describe is a result of it not working any more. With the engine cold start the engine and run at around 2000rpm If the fan is working properly you will hear the air noise from the fan for a few seconds then the noise will dissapear as the fan slows down. When the engine is hot viscous fluid ( silicon ) is pumped from one side in the fan hub to the other creating drag which makes the fan spin and draw air through the radiator. If this is not happening then the fan is stalled by the load of trying to move air and as such the temp rises. As you move off the air flows through the radiator and the fan becomes useless until you stop again. Noemal fix is a new viscous hub. If you have electric fans check that they are working as planned
Jan 11, 2013 | 1996 Oldsmobile Aurora
Fan runs but no cool air or any air coming thru ducts
Be sure the "fan running" noise you hear is actually the fan and not just the refrigeration pump. The unit would still make a running noise but the fan may not be turning.
Check to be sure the filter is clean and that all vents are open.
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
Fan runs but the compressor does not run no
While moving the unit you may have jammed or budged the start capacitor which is keeping your unit from turning on. It is located in the back of the unit near the compressor it is oval shaped and silver in color with two wires running out of it. Get the number off of it, go online and search for beverage-air commercial freezer parts. You will need to have the model number to make sure that you get the right parts. Please rate
Jun 03, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Our ac just suddenly stopped working. the fan inside the house is blowing out air, just not cool air. i checked the ac unit outside and the fan blades are not moving, but can hear something in there making...
probably from the symptoms you describe the condenser fan motor has failed.If the fan is not running and the copressor is you need to shut the power off to the unit until it is repaired, the compressor can susstain damage from the lack of fan, and it is the most expensive component in the system to replace...
Aug 15, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Showcase freezer fan motor makes constant clicking noise
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
May 11, 2009 | Frigidaire FRS26R4A Side by Side...
Fan Not Working
either bad condenser fan motor or fan capacitor
Apr 24, 2009 | Samsung AW0503B Air Conditioner
Sharp AF-S85FX Air Conditioner - Fan does not work
your fan is stuck and if you continue you may hurt the pump.
it may just need some oil on the outside bearings.
open the unit and see whats going on.
Jun 12, 2008 | Sharp Heating & Cooling
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Goodman CKL30AR30 Air Conditioner Logo
47 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
