Question about JVC AM FM CD DET FACE CAR STEREO
JVC KD-A535 my stereo wouldnt turn on but if i hold the EQ button it turns on once i let go it turns off i dont know what the problem is??
SOURCE: How do i set the time on my JVC KD-G320
press and hold sel button for a few seconds untill it shows demo, release and press right or left arrows untill it shows time hours or minutes, turn volume knob to set time and press sel button to set
Posted on Jul 31, 2008
  • 341 Answers
SOURCE: How to install JVC KD-G396
Here is the manual.
http://www.jvc-australia.com/JVCstores/PRODUCTS/357/ATTRFILE_File3/KD-G245-396%20Inst.pdf
Posted on Dec 20, 2008
SOURCE: cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Posted on Jan 18, 2009
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
How do i set the time on my car stereo it's a jvc kd-r200
Hold the SEL button to bring up the PSM menu, use up/down to select CLOCK H for hour or CLOCK M for minute, turn the knob to adjust, and press SEL to set.
Full details are on page 3 of the manual.
Mar 10, 2012 | JVC KD-R200 Car CD/ MP3 Player
How do i set the clock on my jvc kd-g420 ?
Setting the clock is usually done on JVC head units by pressing and hold both the EQ button and the SEL button, keep them pressed for about 5 seconds and a menu of options should show and you can scroll through the menu with the forward and back buttons.
If the above button combination does not work, you can try pressing and holding the SEL and DSP buttons and holding for about 5 seconds.
Mar 01, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do you set the clock on the kd-g120r jvc car stereo
Turn the tuner on then push and hold the SEL button which is at bottom left of radio and then turn knob until CLOCK is displayed.
Apr 04, 2010 | JVC KD-G120 CD Player
How do you set the time on the jvc kd-s35
Press and hold SEL button. Press ^ button 3 times to display H (hour) turn volume knob to change hour setting, press down 1 time to select M (minute) turn volume knob to change minute setting. Press SEL to finish the proceedure. Reference page 14 in this link to your JVC KD-S35 instruction manual.
http://books.jvcservice.com/Download/106224402/GET0563-001A.pdf
Nov 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Set clock on car stereo
If you press and hold the menu button, it will allow you to scroll thru options and one is set clock...turn the dial to adjust.
K
Jun 21, 2009 | JVC Arsenal KD-AR300 CD Player
I need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Apr 12, 2009 | JVC AM FM CD DET FACE CAR STEREO
I DONT KNOW HOW TO SET THE TIME ON MY JVC KD-G210 STEREO
Directions:
Press "select" button for more than 2 seconds.
Press the fast forward button to access hours.
Turn the dial (knob) to the appropriate minute.
Press the fast forward button to access minutes.
Turn the dial to the appropriate minutes.
Press the select button.
You should now be able to see the time on the display.
Reference: http://resources.jvc.com/Resources/00/00/94/GET0246-001A.pdf
for any other issues.
Let me know if you have any problems.
Feb 10, 2008 | JVC KD-G210 CD Player
Can't set clock
hello Have radio on and then you have to hold down the SEL button on left for a few seconds. Then it will say "SET H" which is hour and turn volume dial left or right to move up or down. To set the minutes push either the left or right buttons on the selector on the far right. You can switch from minutes to hours here too. And once at "SET MIN" turn the volumes dial to go up or down. Hope it helps!! Took me a awhile to figure out (no manual here)
Dec 06, 2007 | JVC KD-S890 CD Player
Aug 26, 2007 | JVC KD-G320 CD Player
JVC KD-G720 car stereo - how to change the time?
Press and hold the SEL button to bring up the settings menu. Press and release the tuning (>>>) buttons until you see CLOCK H. Turn the volume knob to select the hour. If necessary, press (>>>) for CLOCK M; adjust the minutes setting with the volume knob. Press SEL when you're finished. An owner's manual can be downloaded from JVC at this link: http://books.jvcservice.com/booklist.asp?Model=KD-G720J
Mar 15, 2007 | JVC KD-G720 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
