Question about Canon imageCLASS MF-4350D - 23 PPM Multifunction Desktop Monochrome Duplex Laser Printer, Copier, Scanner, Fax Machine, 2711B001, MF4350D, MF 4350D
Printer error 9781 - Canon imageCLASS MF-4350D - 23 PPM Multifunction Desktop Monochrome Duplex Laser Printer, Copier, Scanner, Fax Machine, 2711B001, MF4350D, MF 4350D
Dryer not heating
Someone will need to take it all apart and check the heating element with an electric meter, and also the fuse if it has one, and each of the overheat thermostats. ( it may have as many as 4.)
If one of the thermostats or the fuse has failed, be certain to verify there is no lint in any of the vent pipes inside the machine, and a very clear vent pipe to the outside air.
God bless your efforts.
Dec 01, 2015 | Kenmore 9781 Electric Laundry Center with...
I have a rather elderly but fully functioning Canon CP-330 which I used with my PC running Windows XP and my iMac running OS X
Get Windows 7 Driver from webpage
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/cp_330#DriversAndSoftware
Press on Drivers & Software
Select Windows 7 32 or 64 bits, depending the one you have
Download it and install it
Can't help you with OSX; your printer should work, no idea why it doesn't but then, I don't know much about OSX.
May 04, 2015 | Canon CP-330 Thermal Photo Printer
When I do a wash my dark clothes have white streaks after drying. What do I do?
find the crayon or chalk in the machine. To isolate the issue, line dry some clothes and see if they come out ok.
Jan 07, 2015 | Kenmore 9781 Electric Laundry Center with...
Print Error 9781
send me sotware panasonic kx-mb772 to download
Dec 20, 2013 | Epson CX8400 All-In-One InkJet Printer
How can I order pressure switch as the one in machine need replacement?
Hello Dorothy,
Welcome to Fixya, I hope to provide you with enough assitance to enable you to move forward, if not provide a solution altogether.
Based on the limited info you provided "How can I order pressure switch as the one in machine need replacement?" I'd suggest you first check on-line at the web page provided here...
http://www.searspartsdirect.com/partsdirect/part-number/21001554/0026/464?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=21001554
This should direct you to the "searspartsdirect" web site displaying the pressure switch most likely needed, (part #21001554 as shown in the picture at the bottom of this post) though this is based on only a partial model number listed in your post, 9781.
There a varity of part (spares) distributers on-line who offer free shipping in many cases, but it's best for you to be sure it is the part required and to inquire with a complete model number that you'll find on the inside of the dryer door on most combo stacker washer & dryers.
Hope this provides you with adequate info to at the very least move forward. Good luck.
Regards,
Macmarkus :)
Feb 20, 2012 | Kenmore 9781 Electric Laundry Center with...
Won't stay on when button is pushed, HOLD button down it will run but not heat !!!! PLEASE HELP !!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 04, 2011 | Kenmore 9781 Electric Laundry Center with...
6292 - 4128 - 9660 - 2706 - 0745 - 7711 - 1163
Do you need an authorization code for that activation number?
Try this one.
4973 9158 1037 6156 9781
Mar 19, 2011 | Adobe Photoshop CS for PC
Washer is leaking
sounds like you have a hose problem. are the hot and cold water hose connections tight? they may need new washers. if that is the problem turn off water valves,disconnect hoses and replace them with garden hose washers from any hardware store. re-tighten them snugly. just tight enough so they don't leak. if it only leaks while draining, replace the short hoses connected to the pump,located inside bottom of inside of washer.
Sep 16, 2010 | Kenmore 9781 Electric Laundry Center with...
Canon imageCLASS MF-4350D - 23 PPM Multifunction Desktop Monochrome Duplex Laser Printer, Copier, Scanner, Fax Machine, 2711B001, MF4350D, MF 4350D Logo
21 people viewed this question
old marine
old marine
