Lg fuzzy logic WF-S5605PH washing machine - Washing Machines
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
  • 5418 Answers
SOURCE: Lost manual to LG washing
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Posted on Jun 13, 2011
FitzOriginal
  • 842 Answers
SOURCE: my LG washing machine model-fuzzy
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Posted on Jun 23, 2011
caroldon
  • 17130 Answers
SOURCE: my LG washing washing machine Fuzzy Logic 6.5kg WF-T6560NT won't drain
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jun 12, 2012
Lg washing machine model wf t652a fuzzy logic wont spin
check pump is not blocked or faulty if good its probably the brake motor
Oct 25, 2017 | LG Washing Machines
Lg fuzzy logic manual wf
You can download the manual on LG's website at LG.com/ca_en/appliances
Aug 29, 2014 | Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
