Question about Goodman Heating & Cooling
Fan running after unit was turned off. It was running for over 45 minutes
    Genius:
  • Goodman Master
  • 1,363 Answers
Fan relay stuck in.
Posted on Aug 14, 2015
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Posted on Aug 14, 2008
  • 534 Answers
SOURCE: Heat / Cool unit runs approx 45 minutes then trips the breaker
Check the amperage of the breaker or change the breaker out completely with a new one. The tripping problem is that the breaker itself is heating up to the point that the bi-metal in the breaker (safety device) is throwing the breaker off. This could be the problem for you however, I would get an ampherage draw from the unit to insure that the breaker is the proper size for the unit. If you can find what kilowatt the unit is divide that number by the amount of current being supplied and that will give you the breaker size.
Good luck hope I helped you some
Dave
Posted on Jan 08, 2010
The fan in the compressor for the HVAC unit quit running last night this morning after 2 attempts it started and ran fine , cooled form 76 to 72 in about 45 minutes, but when I tried to start it again the...
Replace the fan motor and capacitor. If you want to go the cheaper route, change the capacitor first and try to run the unit. The cap. is what gets the fan motor running on start up. Another way to test it is to manually turn the fan bade and while it's still turning, make sure your hands are clear of the blades and turn the condensor on. If the fan runs normally, then it's your fan capacitor.
Jul 02, 2011 | Amana Heating & Cooling
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
Motor runs, but dehumidifier does not collect water
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. The fan running, may be the automatic defrost cycle, that defrost the coils, if they become frosted over. The defrost cycle, depending on the unit and how is was designed, can last any where from 15 minutes up to 45 minutes.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Whirlpool Dehumidifiers
Does a bathroom require an exhaust fan even if it has a window
YES!!!! all a window does is change the vapor into liquid. What is needed is to get the moisture OUT OF THE building. I prefer Neutone 200 CFM unit, for get specs, they are all way too low. You are combating health issues if you allow moisture to remain....mold...
Also, the exhaust ducting needs to run downhill as it exits the building, or you risk moisture dripping from the fan...
Futher, put a 60 minute timer on the fan, and run 45 minutes (at least) for every shower....
Aug 28, 2010 | American Standard Home
SPLIT AC NOT COOLING AFTER 30 MINUTES
sounds like the out door fan is not running and the comp is over heating, rec to start unit and check to see if the fan is running in the first 30-45 min, if not check cap or replace fan motor.
Jul 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The fan is running and blowing cool air out of the unit but there is no air coming through the vents, what are the possible problems? (Lennox Elite series)
The unit could possibly have a frozen indoor coil. Turn ac to off...and fan switch to on...wait 45 minutes and see if air flow improves. Check for dirty filter which can lead to freeze up. Low on freon is also a possibility.
May 18, 2010 | Heating & Cooling
I have a samsung HT-Q100 and its plays well but it will turn off itself after 45 minutes of playing time. I've check the back of the player and it heats up really hot( on the right of the fan at the back)...
If the fan is not providing sufficient cooling (it could be that the fan needs replacement), try placing a portable fan where it blows on the back of the unit. If the unit continues to work, you'll know you need to replace the fan within the unit.
Mar 07, 2010 | Samsung HT-Q100 System
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
8 bottle wine cooler unit won't cool
First, see if the fan is actually blowing anything out of it. YOu may have an obstruction. If not that...Generally, there are three reasons that you won't get cooling:
  • The condenser radiating fins on the unit are dirty which won't allow cooling air flow to liquify refrigerant. Clean them.
  • The unit is frozen up inside because of excessive humidity. Defrost the unit by leaving it off and open for a day.
  • The unit is low on refrigerant. Check this by leaving the unit off for one hour. Locate the pipes coming out of the compressor. Turn the unit on. If the larger pipe stays frosted up for more than 15 minutes, you need to get the unit charged.
Jan 04, 2009 | Dryers
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Heating & Cooling Logo
29 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
