Question about Acer Aspire E380 ASE380-UD500A PC Desktop
ASE380-ED501A NOISE CPU FAN - Acer Aspire E380 ASE380-UD500A PC Desktop
2 Suggested Answers
katemestr21130
  • 83 Answers
SOURCE: What is the case fan size for a acer aspire ase380-ud440a desktop computer? Also what size is the CPU fan?
no need to replace just remove the label sticker from the fan and remove the smaller lock from the fan shaft be care full its very typical to remove that lock just use 2 needle with one needle press and hold the lock with other lift up lock from the cut side lift up the lock and remove the fan from bushing just clean both bushing and fan shaft with any rust remover cleaner clean well after clean both just apply any kind of lubrication oil and re assemble the fan it will be free of noise.
Posted on Jul 14, 2014
Testimonial: "I removed both labels from the CPU fan. On one side under the label is just smooth black plastic. On the other side there is a molded plastic center disc with 4 small plastic arms radiating out to the case . Where is this lock you are talking about? I can see the windings but I don't see anything like a lock. Thank you for answering anyway."
What kind of cpu cooling fan can I use in a Acer America ASE380-UD420A desktop computer?
Cooling fan to CPU are come along with the CPU. You can use any other fan, having speed regulator pin, ie, the connector wire to it will have three conductors. Keep a close look at the size and seating screws to its body to the heat-sink of the CPU.
Jul 22, 2014 | Averatec Sotec 3200 Series Fan with...
Jul 14, 2014 | Acer Computers & Internet
What could be causing a load whiring sound in Acer Aspire ASE380-UD440A
The CPU fan. This is normal. Use canned air to blow dust out if it has become louder than usual.
Oct 08, 2012 | Acer Aspire E380-UD420A (ASE380-UD420A)...
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
EXCESSIVE FAN NOISE
pls change ur fan as soon as posible
Jun 20, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
My pc turns itself off as soon as I switch it on, the fan seems to make a loud noise, if I leave it for a while, then switch it back on, it does a disk check but eventually turns itself off again. Could it...
Hi
Which fan. If it's the power supply fan then the power supply needs to be replaced. It could be damaged due to a heat related issue. Most likely it's the CPU fan that is going bad. Once the fan stops then the CPU heat goes up dramatically, the CPU then shuts down because of the high heat. CPU may be damaged also. Get this machine to to a reputable repair person as soon as possible.
Mar 24, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire E380 won't start. When powering on the cpu fan runs at high speed but nothing else operates. Disc drive etc.
plug out the power cable connected in your CPU and replug it again still its not working you need to change the power cable
Dec 19, 2009 | Acer Aspire E380 ASE380-UD500A PC Desktop
Mother Board Fan Making too Much Noise
There are 2 main reasons for the CPU fan to run noisily.One is that there is film of dust accumalated on the cooling fins thus not allowing air to circulate and cool the CPU properly.The second is that perhaps the fan needs to be oiled because the sleeve bearing has gone dry.The most common problem for a noisy CPU fan is accumalation of dust.You will have to remove the fan and clean it thoroughly with a soft brush.
Dec 21, 2007 | Asrock 845GV (P4I45GV) Motherboard
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
