Question about Electronics - Others
Is there a remote on off switch made for pi 1000 duralast inverter and where can i get one
2 Suggested Answers
  • 242 Answers
SOURCE: on a 1000 watt Duralast inverter what area code is lup
this is a question for a qualified electrician
or ring the store where you bought it from
Posted on Mar 19, 2015
I reverse connected my duralast 1000w inverter, now it won't turn on. How do I fix it?
inverters run on a series of diodes and if you have reversed the connection then there is every possibility that there is massive board problems
there may be an internal fuse or overload switch
I suggest that you take it to an electronic repair shop and have it checked out.
Aug 30, 2015 | Cars & Trucks
On a 1000 watt Duralast inverter what area code is lup
Mar 19, 2015 | Inverter Electronics - Others
What is volume in litres of a bag 230mm dia x 450mm long?
You give only two values for the dimensions, so it must be a cylinder with a radius r=230/2 mm= 115 mm= 11.5 cm
and a height of h= 450 mm =45 cm
The volume for your right circular cylinder is V=PI*(r^2)*h=PI*(11.5^2)*45 cm^3=?
Divide the result by 1000 to convert the volume to liters (1 L =1000 mL=1000 cm^3)
Jul 03, 2014 | Office Equipment & Supplies
Vertical cement pipe 6mtrs deep in ground, 60cms in diameter. How do I get the volume of water in litres?
The volume of a cylinder is pi*l*r^2, where l is the length and r is the radius (and pi, of course, is about 3.14159).
pi * 6m * 0.3m^2 is just under 17 cubic metres (17 m^3). A cubic metre is 1000 litres, so the volume is about 17,000 litres.
Feb 26, 2014 | Office Equipment & Supplies
Pi-400w power inverter manual of service
Double check whistler's website for a manual ( PI 400 Power Inverter ) or call 800-531-0004
Sep 21, 2013 | WHISTLER PI-400W 400-Watt Power Inverter
Change fuse Duralast 130w inverter
The fuse is located in the "plug", (that which you insert into the cigarette lighter). Simply unscrew the end of the plug to reveal the fuse.
- linuxskynyrd
Jul 27, 2012 | Electronics - Others
Need duralast inverter remote switch
good luck, i dont even think they make one. just get a phone cord plug it in and see which two wires make it turn on. touch them momentarily to see..........you know what i'll just do it and report back
Jul 16, 2012 | Electronics - Others
Calculate the value of pi
#include <iostream>
int main(int argc, char *argv[])
double arctangentOfOne = 0.0;
for(int i=0; i < 1000; ++i, std::cout << 4 * arctangentOfOne << std::endl) arctangentOfOne += (i%2==0?1.0:-1.0)/(2*i + 1 );
system("PAUSE");
return 0;
Jan 15, 2009 | Microsoft Windows XP Professional With...
I have to power 1800 w for 12hr a day! I currently have Vector Max SST 3000w 20 Duralast 31-950 950 Cold Crankin Amps 195 Reserve Capacity Schumacher se-3000 Charger Do i need to change or add anything to...
I think the problem might be your battery setup.
First of all, these batteries are not deep-cycle batteries they may not tolerate this kind of usage. Secondly, if you have 20 batteries connected in parallel they could end up working  against each other (draining each other) all the time.
You might do better with 2 very large 6 volt deep-cycle golf cart or fork lift batteries.
Jan 05, 2009 | Vector Maxx SST Power Inverter
Electronics - Others Logo
60 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
