Question about Altec Lansing VS4121 Speaker
Altec Lancing VS4121 speakers
I just purchased Altec Lancing VS4121 speakers and hooked them up to my computer but when I use them there is an echo or reverb that makes it almost impossible to distinguish words etc. My computer has Vista for an operating system. Thanks
  • 2 more comments
  • pattio Aug 10, 2007
    Problem Solved. Just had to change settings on computer
    Problem Solved. Settings re-set.
  • Anonymous Jan 04, 2008
    Yes I have the same problem, my speakers are Logitech with 5 speakers and a sub woofer. I changed the setting description (analog,digital etc. ) What next?
  • datkins2 Jul 01, 2008
    Getting echo-sound tunnel sound from speakers I purchased for my partents. I understand it may be a "Settings" problem, but can't figure out which. Can u help?
6ya staff
SOURCE:
Anonymous
SOURCE: No Power (LED off) in the Altec Lansing VS4121
There is a fuse on the power supply board which is held in place with 4 screws. Yiu will have to unplug the sub-woofer connector to remove it.
Posted on Apr 15, 2008
Anonymous
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
Anonymous
  • 6 Answers
SOURCE: I have connected my philips 5.1 channel dvd player
to get 5.1 you need to have an optical/co-axal/hdmi input in to the speakers to get 5.1 and then the dvd player must have one of them as an out put
hope that helped
Posted on Jun 19, 2009
SOURCE: my speaker altec lansing vs4121 is just humming
Check the audio amplifiers Ic´s maybe are burned
Posted on Aug 10, 2009
marlon_glodo
  • 48 Answers
SOURCE: i have an altec lancing model VS3251, wondering
try opening the center speaker or the woffer casing, check the out put amplifier ic, it is burn out
Posted on Jun 19, 2010
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
How to open the subwoofer housing to change the fuse
on the back unscrew all the screws (there should be 8 in the plastic square around the jacks... and then undo the four that are in the wooden back) then pull out the plastic square, it will take a decent amount of force, try prying with a flat head screw driver. Once you have that out, you should be able to access what you need inside.
May 30, 2010 | Altec Lansing VS4121 Speaker
Is is possible to install altec lansing speakers
It is possible to hook up these speakers to a laptop according to this brochure:
http://www.alteclansing.com/images/spec/vs4121%20sell%20sheet.pdf
Now this manual shows those speakers being hooked up to a computer but laptops have the same outputs as well so here it is:
http://www.alteclansing.co.uk/images/quick/vs4121qcc.pdf
you'll need adobe reader to read the manuals.
May 17, 2010 | Altec Lansing VS4121 Computer Speakers
Computer won't recognize that there are speakers plugged in
go to the pc support website---the should be access to drivers for your model
Apr 27, 2010 | Altec Lansing VS4121 Computer Speakers
Vs4121 altec lansing left speaker wire ripped.
Black should be ground and red is usually the actual audio cable. If you connect them wrong the should not short. They will just sound weird until you connect them properly.
Hope this Helps
Thanks for reading!
May 02, 2008 | Altec Lansing VS4121 Computer Speakers
Try going to the volume control panel, and clicking "mute" on the Mic Volume. this should fix the echoing
Jan 09, 2008 | HP P5302M Computer Speakers
Lost set up disc
go to the website of the company and just simply type the model no. u will get all the details and u can download a cd content too.....
Dec 03, 2007 | Altec Lansing VS4121 Computer Speakers
Altec VS4221 not working with Gateway
I am guessing that the speakers our connected to the input port.. make sure it not plug on the input port...
Jun 16, 2007 | Altec Lansing VS4121 2.1 Channel Powered...
Altec Lansing VS4121 Speaker Logo
44 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
