Question about Whirlpool Washing Machines
Whirlpool 17 kg 6th sense Mod 7MWTW1709YM lid switch Bad I think....Just has a light flashing says Seguro Tapa {secure lid} And the Pump runs .. No spin no fill with water no Wash
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
srsrs_1999
  • 9 Answers
SOURCE: washer only fills. then completly dead.(timer still advance)
is there any humming coming from under or front of your washer? whirlpool built machines for about 10 years now are "direct drive" ...the motor has a plastic coupling held in place by a rubberish plastic donut type of thing, its an inexpensive fix and there are videos on youtube on how its repaired..its under 10 bucks and usually cures any lack of agitation/ spinning ...i had a roper by whirlpool and once i replaced it from a parts machine i salvaged it was fine.. so check you motor coupler/ coupling and that maybe your answer, if not there is a set of wires and a cut off in back of the motor to prevent overheating, which may have tripped..also a good point to check.. good luck
Posted on Apr 30, 2009
  • 212 Answers
SOURCE: Our Whirlpool thin twin stopped after filling.
replace lid switch
Posted on Jun 20, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
Whirlpool 6th sense - pump issue
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Jan 20, 2013 | Whirlpool Washing Machines
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
There is a flashing #6 in a circle above the temperature indicator. What does this mean?
Mine did the same thing today and I just got off the phone with Whirlpool and they said it just means that the 6th Sense technology is activated. If you put a bunch of warm food in the refrigerator or leave the door open for a while, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Nov 21, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Whirlpool 6th sense front loader awm 8121
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Not spining
sounds like the lid switch.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
