Gme Tx610 Manual
Clicking when on standby and the signal strength indicator blinks
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
Daewoo TV problem
that is standby mode! maybe you have defective power supply in oscillation circuit! at hot side..
Oct 03, 2007 | Televison & Video
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
When I turn the projector, i hear clicking from my AV receiver, the MITSUBUSHI screen then blue screen shows up on the wall, but then it says no signal: then the projector goes to standby without me doing...
The problem is most likely a warped plastic housing around the color wheel. When the wheel is forced to stop, the projector will go to standby and the lights indicate a problem.
Apr 23, 2017 | Mitsubishi HC5500 LCD Projector
Tc-p50x1 will not turn on red light blinking one time.
1 times standby light blinking indicates problem of standby 5V time out signal and possible cause of this problem is either few leaky capacitors in P board or A board is defective.
Please check/ replace accordingly to solve tv problem.
Thanks.
Feb 17, 2011 | Televison & Video
Casio atomic watch only has intermittent receive indicator
The receive indicator tells you the strength of the signal when the timing signal was transmitted, (this occurs only during the night).
The strength of the signal dictates how much of the indicator is shown i.e. full strength, full picture, half strength, half picture, no picture, no signal.
Signal strength seems to vary with location (how far you are from the transmitter), so perhaps you are in a poor reception area.
Feb 26, 2010 | Tissot Diver Seastar 1000 T19.1.593.51...
I can't make calls from my Blackberry 7290
Check on the right hand corner of your device for the vertical signal bars - 5 bars indicate full strength and 1 indicate very low signal. "OFF" indicates the radio is off and need to be turned on.
In case signal strength is good, you should be able to make and receive calls. In case it does not work, just try taking the battery out and put it back after 15 seconds and try again.
In case signal strength is low , either you are in a low signal zone or your SIM card is bad. Take the SIM card out, wipe the gold plated surface using a clean tissue, put it back and try again.
In case the radio is OFF, turn it on by clicking on the icon (Turn Wireless on) on the home page.
Dec 27, 2008 | RIM BlackBerry 7290
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Standby Light Blinking
Standby light is a signal indicating a voltage trouble on your system . It could mean a compoment is defective or a power regulator needs replacement worse is a system IC replacing. you better bring your stuff to a Sony service center and do a check on your TV system.
Apr 09, 2008 | Sony KP-53HS10 TV
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
