I have a vizio sv470m that only the top 2" of the
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Check the flat connection wire [LDVS] cable that connects the T'Con board and LCD panel for any loose contact. Re-set it once and check. If it do not help yoy, the T'Con board should be replaced It is faulty. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
SOURCE: my vizio sv470m screen keeps distorting the images
Could be power board, could be main board, could be LCD controller and lastly - very unlikely yet possible - could be cables or rather cable connections.
It would help a lot if you post a screenshot or, better yet, a video of the distortion.
I somehow do not relate "distortion" and "blacking out".
Yet if I had to make a pick based on what you say and my experience I'd look at the main board first.
You should be able to get a replacement for under $100 at eBay and if you know what a screwdriver is you should be able to replace it yourself - a slow, but certainly not difficult process even if you do it for the first time.
Still I don't recommend spedning money before sharing more details and getting a more informed guidance as to where to look.
Posted on Nov 02, 2009
Testimonial: "that sounds like an excellent solution. I'm going to give a call to vizio to ask for all the required parts and take your advise and do it myself. ty!"
SOURCE: Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Posted on Mar 18, 2010
  • 11 Answers
SOURCE: Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Posted on Apr 18, 2010
budmrtn
  • 11361 Answers
SOURCE: vizio model sv470m screen went
Blank on ALL video modes?
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Feb 16, 2011
HDMI makes black screen
IT sounds like the ccfl tubes (the bulbs that help light your tv) are going out. Think about replacing them. You'd need to take it in to get this done. Also, it may be cheaper just to replace the TV entirely, given the cost of replacing the tubes.
Good Luck!
Dec 05, 2013 | Vizio SV470M LCD TV
Vizio sv470m
Try unplugging all units involved for a while--make the HDMI connection when they are disconnected from power--HDMI does not like being hooked up to units that are powered and or on.
Jun 14, 2012 | Vizio SV470M LCD TV
Vizio SV470M Issue Sound No Picture
Do you have backlight? If you do, you have a bad main logic board. Very common with vizio and are hard to find. They are usually out of stock everywhere.
Oct 31, 2011 | Vizio SV470M LCD TV
How do i set the color on my vizio sv470m. it has
Your main problem is that you bought a cheap Vizio tele instead of a Samsung or Sony.  Theres a reason why these teles are cheaper.  They have barely any quality control.  Don't buy a tele cause a football player says its all good.  Try going into the settings and adjust the contrast and hue or take the thing back to the shop for refund if you feel this unit is just rubbish.
Cheers.
Oct 30, 2009 | Vizio SV470M LCD TV
My vizio sv470m screen keeps distorting the images after being on for a couple of minutes. if i leave it alone, eventually the distortion will be so bad that the entire screen blacks out. i have to turn it...
Oct 22, 2009 | Vizio SV470M LCD TV
Horizontal line at top of screen in any hd format with componet or hdmi. model is sv470m. the tv isn't even a week old.
Get into the TV menu and locate the H (Horizontal) and V (Vertical) picture options. . .increase the V until line at the top is gone.
Oct 20, 2009 | Vizio SV470M LCD TV
Sep 24, 2009 | Vizio SV470XVT 47 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
