Question about Minitab 14
Mintab 16 every time I start the program it gives me this error code and says it can't authenticate 800401F3
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
Sep 01, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
I can't get my Toshiba Satellite to authenticate its OS after using the Recovery diskt that came with this laptiop when I bought it new from wal*mart.com.
When installing from a recovery disc it should not need to authenticate. You can do it manually. You didn't provide your operating system so I can't give exact instructions but in general, when it asks you to authenticate you can let it try online. If that fails you can call the phone number provided.
For Vista left click my computer, then properties, then scroll down to activation and click activate.
For XP click start/ all programs/ accessories/ system tools/ activate windows.
Then just enter you keycode.
May 23, 2011 | Toshiba Satellite A55-S1063 Notebook
I just purchased the device and trying to load it through www.jamb.org.ng/Unifiedtme/ registration platform but the response received is authentication error i.e. I can't thumbprint.
You will get this kind of error "authentication error "
1. This kind of problem happens when you re-formatted your computer
2. You just install your scanner this year for the first time.
3. You did not have biometric license key installed on your computer, this license makes your scanner authenticated over the internet when you are visiting jamb website, if you are in Nigeria. It also comes with Jamb Biometrics Capture Software, .Net Framework, Java Framework and other software that will make your experience very simple after installing.
4. If, you have the license, then you did not supply the 16 digit security code for the scanner.
The way you out, you need BIOMETRIC LICENSE, if you are operating JAMB BUSINESS.
Hope this help you, if you need more clarification you can email me on biometricmasters2000-jamb at yahoo.com or phone me on 08132829820
Dec 29, 2010 | DigitalPersona UareU 4500 Fingerprint...
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Oct 31, 2010 | Sharp Office Equipment & Supplies
How to download hwk update client v 2.1.0
Upgrade log:
---------- HWK Update Client v 2.1.0.0 ----------
---------- HWK upgrade started:6/2/2011 6:35:55 AM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 78650
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-DE6985914260006D
-- HWK Status : 1, DL: 0
Oct 07, 2010 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Help me
Replace the fuser. H means HEAT
May 14, 2010 | Sharp AL 1631 Copier
Minitab 14 Logo
100 people viewed this question
Top Minitab Computers & Internet Experts
David Payne
David Payne
Are you a Minitab Computer and Internet Expert? Answer questions, earn points and help others
