Question about Dryers
Red lion cement mixer
The motor won't turn the drum. i thought the motor bushings were worn and replaced the motor but the new motor won't turn the drum either. i can turn the drum by hand by pulling on the chain.
larryyb
  • 291 Answers
SOURCE: dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Posted on Dec 05, 2008
  • 686 Answers
SOURCE: drum not turning
no brushes in those motors you need new one or different dryer
Posted on Mar 12, 2009
  • 58 Answers
SOURCE: Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
Posted on May 05, 2009
  • 82 Answers
SOURCE: Hotpoint VTD00 Tumble dryer. Motor runs ok without
The motor is bad and needs replaced. It could be the contacts or the bearings, either way you have to replace the motor.
Posted on Dec 13, 2009
heatman101
  • 43501 Answers
SOURCE: heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 30, 2011
Cement Mixer won't run or start
Is there power in the wall socket. Check with a lamp?
Does the motor get warm when plugged in for a while?
Does the motor have a starting capacitor? Look for a metal tube on the side an inch or so in diameter. Those are AC electrolytic capacitors that are a common failure item.
Apr 18, 2016 | Food Mixers
MY MINI MIX CEMENT MIXER IS BROKE DRUM WILL NOT TURN WHEN LOADED
This is the food mixer forum, not much cement gets mixed in the kitchen around here, too much danger of a flying rolling pin.
Sep 06, 2014 | Food Mixers
Hi, My cement mixer 240v supply lead has been pulled out of the connection box. Can anyone supply me with a wiring diagram. the only detail on the box is that it was made by POWERFLO drum capacity...
Do you still have the wire with plug end?
The mixer has a switch.
Is the mixer reverse-able?
Or is the mixer 2-speed?
What do you mean about 'one plug' and 'second plug?'
Buy cheap multimeter at hardware. Install battery. Set to read ohms.
Green wire is always ground.
Test each wire to each other.
For example if you test green wire to metal side of mixer, the meter will show full open circuit.
Test each other wire to each other wire. When voltage travels through the motor, then there will be ohm reading.
Move the switch to each position, and see which wires test differently.
Try to identify wires going to switch.
240Volts will have two hot wires.
One or both the Hot wires should connect directly to switch, depending if switch turns one hot wire on-off, or turns both hot wires on-off.
In a two speed system, or reversing system, the switch will send power to different coils on motor.
Sep 27, 2012 | Dryers
The belt keeps slipping off so the drum won't turn
replace the bel, is worn, put a new one. Of course before try to adjust the tension of belt, for moving a little the motor.
God bless you
Sep 22, 2012 | Vacuums
My Zanussi TC7102W drum won't turn. If i turn it by hand the motor runs OK and the drum keeps turning. If I leave it after it stops the motor will not turn again unless I assist it. Looks like the...
That would certainly be my first thought.
Before you go buying a new one though, I would just check that the brushes on the motor are moving freely in their carriers and that they're not excessively worn
Aug 30, 2011 | Dryers
The chopping mechanism, which should turn freely, is "frozen" & won't turn. not even manually.
I'm assuming that this isn't happening on an model in which the bowl can be detached - otherwise the plastic bushing has melted and glued the shaft to the base of the mechanism - it will have to be replaced. You can find one on the Breville site
http://www.brevilleusa.com/blending.html
select yours and you will find it in the Parts &Accessories tab.
The mixer has an plastic bushing on the shaft of the chopping mechanism that is there to connect it to the shaft of the motor. If that bushing or the bearing of the shaft got damaged in any way the entire mechanism will lock out.
To find out what exactly happened you will need to dismantle the mixer - take out the 4 screws on the bottom, unclip the power wire, remove the supports of the motor and pull it out for inspection. Parts from older models can be obtained only from a dealer, you will have to contact one and order it .
Jul 30, 2011 | Breville Blenders
My machine simply won't turn on .
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
Won't turn on
Get a copy of the Repair Part List for your model at Kitchenaid.com
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
Jul 15, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
Hello, We have a mini cement mixer that fell over while turning. It rolled a ways and then stopped. Now the motor seems to be running fine, but it won't turn. Where do you think I should start...
I would find out if it is belt or direct drive. Either way check to see if it put gears out of alignment or idler pulley so that belt can not engage.It may have jarred the motor so that it needs repositioned. At least with the motor runningit sounds to me like you just moved or bent something out of position and it won't be too hard to repair. Good luck and thank you.
Jun 25, 2011 | Bosch Garden
Dryers Logo
44 people viewed this question
Top Dryers Experts
