Question about Kyocera Copystar FS 3140MFP/DP copier
Kyocera FS-3140 manual
Coming up with error 2202. Not allowing to scan?
  • 56 Answers
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Posted on Nov 06, 2007
install new firmware
Posted on Dec 18, 2007
  • 40 Answers
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
Posted on Jan 10, 2009
  • 300 Answers
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Posted on Apr 14, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
How do i clear jam 20 in fs 3140
You can find it on page 375 of the user manual here: http://www.manualslib.com/manual/450403/Kyocera-Ecosys-Fs-3140mfp.html?page=375
just continue with page 376, 377, 378 to follow the instructions ...
Oct 17, 2014 | Kyocera "FS-3140MFP Printer, Copier, Fax &...
Fs 3140 mfp error
Can you be more specific or provide error codes or messages?
Jul 04, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Where is a paper jam in the duplex cover
remove cassette inside underneath there is a green lever pull it down paper should be in there
Jun 27, 2014 | Copystar Kyocera Fs-3140mfp fs-3140 Copier
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Search Fixya...MIta 3140 wont receive faxes
make sure your phone line is plugged into the LINE jack, not the EXT jack
Jul 16, 2013 | Kyocera FS-3140MFP Mita FS-3140MFP 42 PPM...
FS-3140 memory full when scanning
change scan defaults to monochrome, pdf, and 300dpi or lower resolution in command center.
Feb 18, 2013 | Kyocera Copystar FS 3140MFP/DP copier
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Kyocera Copystar FS 3140MFP/DP copier Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
