Question about Ricoh Aficio MP 2000 Black and White Copier
Nashuatec 1805d code error is SC302.Pls.send me guidelines on how to fix this error.thanks
Can I do it myself to repair this code error SC302 on my nashuatec aficio 1805d thanks.
  • 1297 Answers
SOURCE: Error Code on photocopier
Please clean or change the charge roller .The your problem in the HV parts.Verify the drum ground plate.
Posted on Nov 17, 2009
  • 360 Answers
SOURCE: When switching on, my Ricoh
change your charger roller
Posted on Aug 31, 2010
santosj27
  • 263 Answers
SOURCE: The Porblem is Modole No.
This code is related to a Laser synchronization error.
It could be just dust but it also can be a defective Laser unit.
I advise you to call your technical assistance
Posted on Apr 11, 2011
santosj27
  • 263 Answers
SOURCE: my aficio richo 2016 black
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
Posted on May 11, 2011
santosj27
  • 263 Answers
SOURCE: I HAVE A CODE THAT
This error is related to the scanner.
Probably you have a dirty lamp or white plate.
If you are able to do it, try to take the screws of the glass and clean the lamp and mirrors with a dry cloth.
See you!
Posted on May 23, 2011
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
I HAVE A CODE THAT DISPLAY IN MY NASHUATEC 1805D. THE CODE IS SC194
See you!
May 22, 2011 | Ricoh 6513 Copier
SC 302 servis call, command, How can I repair the machine? Pls reply,
SC302 is a charge roller leak. clean or replace charge roller to eliminate this problem. and give the machine a good vac to clean and remove the toner inside the machine.
May 25, 2010 | Ricoh Aficio MP1600SPF Copier
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
I've got error code E3 and someone at Canon
unfortunately, no. Canon will not sell you the parts for repair. They only sell to authorized repair centers.
Thanks for using FixYa - a 5 TUHMBS rating is appreciated for answering your FREE question.
Nov 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
Mar 28, 2009 | Ricoh Aficio 450 Copier
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
85 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
