Question about Cameras
How long to charge a Ni-MH 2/3AP 650mAh 7.2V battery
For an airsoft gun
  • 188 Answers
SOURCE: Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Posted on Jul 02, 2006
  • 39 Answers
SOURCE: Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Posted on May 01, 2008
SOURCE: my digital camera turns on and qwicly turns off
it was fixed by it self
Posted on Apr 13, 2009
BillB-SA
  • 2761 Answers
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Oct 31, 2009
leepania
  • 1099 Answers
SOURCE: batteries don't hold charge any more.
The batteries will only last for about 200 recharges. Depending on how you use the camera and batteries. Try with new batteries.
In order to buy new batteries contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Alternatively buy them directly online.
http://store.kodak.com/store/ekconsus/en_US/list/Accessories/Batteries__Chargers/categoryID.28887900
Posted on Jan 21, 2010
Alternative battery charging
you cannot use any charger that is not used to charge ni-mh batteries car batteries charge at a rate of 5 amps minimum and if you do it will cause serious damage to the charger and batteries
if you want ideas , talk to a battery shop but unless it is designed to charge 14.4 volt ni-mh batteries-- forget it
May 08, 2016 | Cameras
My cordless phone Gigaset A49H is working well. I need to replace battery. Can I use AAA Ni-MH 900mAh 2V battery
if the volts of the old batery is the same with the new u can use it...no matters if the old battery was from lithion only or nikelioum / kadmium . u can use nikelium/magnisium batery too all rechargable are (sry for bad english)
Sep 28, 2015 | Siemens Gigaset A49h Cordless Phone...
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
How to CHARGE CORDLESS DRILL
First, you should know your battery is a Ni-CD / NI-Mh or Li-ion battery. If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
If your old battery is dead, you can replace it with a new one. Ryobi Power Tool Battery
Oct 05, 2014 | Drills
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
Aug 10, 2011 | Mattel Fisher-Price Imaginext Big Foot
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
When I depress the shutter button to take a photo the green light turns to red and will not take a photo. New battery. Help?
Red light indicates battery is out of charged.
What type of battery are you using?
the recommended battery for your camera is the AA Ni-MH batteries
now if your using this batteries Ni-Mh and charged it still id did the same thing., How long you already used this batteries more than 2 years now? If yes it means the battery or the Ni-MH is already defective it means that the chemical contect of the Ni-MH is already crystallized and for you to solve it you need to reconditioned the battery or may be purchased a new battery. Gudluck!
Nov 04, 2009 | Kodak EasyShare DX4530 Digital Camera
My camera just does not seem to hold a good battery charge. I use fully charged batteries and this also happens with Duarcell too. I am only using the camera in the "on" selection.
Some digital camera **** the life out of batteries, especially the older ones, even when off. It stores info like date and time etc. I take the batteries out when I am not using it for a while. True it is a pain resetting the time but it saves the batteries. Also go for the top line rechargebles,
Oct 30, 2009 | Kodak EasyShare C875 Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Cameras Logo
131 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
