Question about Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ
FREEZER my freezer sounds like it is running but it wont freeze?
  • berniesmith1 Jul 17, 2008
    food not freezing and red light staying on
    Novelist:
  • 87 Answers
If there is no cooling on the evaporator or only partial cooling then you probably have a gas leak, or the compressor is not pumping correctly. Either way you would need a professional diagnosis. Either way not a good scenario. Hope this helps.
Posted on Aug 18, 2007
Why does my freezer not freeze?
Sound like a typical low freon Issue. Check out our articular on recharging residential refrigerators and freezers
On Time Appliance
If it Helped follow us on our Google plus page.
On Time Appliance Google
Jun 29, 2015 | Freezers
My ge freezer wont freeze
Did you lay it down when you moved?, if so you may have oil in the lines . Did you bump any Freon lines and cause a leak?
Aug 31, 2014 | Freezers
Can only get freezer to work when quick freeze is turned on
Your thermostat is faulty. Run it in fast freeze mode until you can get it replaced
May 04, 2012 | Freezers
Freezer model FCF88W when started up for the first time it sounded like it was gurgling. It gave the impression that water was running Setting is on number 4 for initial start up and the unit got up to...
well i hope when you got this unit and put it in the place were its going to live in for its life you let it stand for a good fuw hours before you powerd it up??? thay need to stand to let the compresor oil and freezer gas find there way to the bottom of the unit,,,if not,,,well naughty you!!! smack your legs!!
but dont worry about the noise its normal for it to gurgle,,,,its the freezer gas being pumped around the unit,, if its freezing its working ok,,and not that it is you can run it at were ever you like,,,up to flat out if you wont to make ice sheets for mountains????
and by the way some times mine sounds like a very hungry hippo,,,especilally in the middle of the night,,, and it keeps me awake!!!
Jun 27, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Freezer
hi thanks for the question first is the compressor running if it is & not cooling . your freezer has lost its refrigerant if so not worth repairing worstthing people do is not use a freezer for a long period of time its ok for fridges as they are built different thanks the appliance doc
Sep 26, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ Logo
428 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
