Z3101 tried to do system recovery. when it start up is say windows could not complete the installation. To install Windows on this computer, restart the installation. I did and it repeats the same things. What do i need to do?
  • 3,799 Answers
If you are having difficulties with installation the problems could be a number of things. Faulty Optical drive (CD or DVD) Faulty hard drive or a faulty recovery partition. The failed hard drive is most likely in your case. To test the hard drive you should get a HDD management suite from someone like Seagate. This will allow you to check the physical functioning of the drive and its ability to read and write.
Posted on Apr 30, 2013
  • 90 Answers
SOURCE: I bought new laptop and
Try booting your system with the Windows installation CD.
Thank you.
Thomas
Posted on Nov 16, 2008
vegeta0264
  • 23 Answers
SOURCE: Cannot change operating system on Gateway GM5478?
Make sure you have enough hard drive space. Also make sure you have enough RAM to support the Operating System
Posted on Dec 06, 2008
gsessons
  • 26 Answers
SOURCE: Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Posted on Mar 19, 2009
  • 192 Answers
SOURCE: I am doing a clean
Ok, first blets try and use the eRecovery program.
When you turn the system on, and it displays either the ACER logo or black screen with white writing, press F2 or Del to enter setup. It should display what to press in the bottom left corner of the screen.
This will open the BIOS settings. There should be a tab at the top called Main, select it. Somewhere on the list there should be something called D2D Recovery. Highlight it, and make sure it's Enabled. Now, while it's highlited, it will display what keys you need to press to start the recovery program. This is usually Alt+F10. Now save your settings and exit.
The system will now reboot. When the ACER logo or black screen with writing appears, press the keys that you saw in the BIOS. The Acer eRecovery program should now start. Follow the on screen instructions.
Hope this works, let me know
Posted on Apr 11, 2009
yboyandrei
  • 828 Answers
SOURCE: Roxio Media Manager Keeps Trying to Install
the Roxio Media Manager is belong to the system, and this part the program is in need to run part of the system...
Posted on Jun 17, 2009
Oxc000012f win7
I would suggest you to follow these methods.
Method 1
Last known good configuration
It's a Windows startup option that uses the most recent system settings that worked correctly. Every time you turn your computer off and Windows shuts down successfully, important system settings are saved in the registry. If a problem occurs, you can restart your computer using those settings. For example, if a new driver for your video card is causing problems, or an incorrect registry setting is preventing Windows from starting correctly, you can restart your computer using Last Known Good Configuration.
1.Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer by clicking the Start button, clicking the arrow next to the Shut Down button, and then clicking Restart.
2.Do one of the following:
·If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by shutting down and restarting your computer.
·If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
3.On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration (advanced), and then press Enter.
4.If your computer has more than one operating system installed, use the arrow keys to highlight the operating system that you want to start by using Last Known Good Configuration, and then press Enter. Windows will then resume starting normally.
Method 2
Chkdsk (Chkdsk.exe) is a command-line tool that checks volumes for problems. The tool then tries to repair any that it finds.
1.Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on Command prompt.
6. Type the command chkdsk and press enter
Method 3
Offline system restore.
1. Boot from the DVD
5. Click on System Restore.
6. Choose the date to which you want to restore
Refer this link for more information.
A Windows Vista-based computer that has a Windows Recovery Environment (Windows RE) partition is not successfully restored by using Windows Complete PC Backup and Restore
http://support.microsoft.com/kb/946010
Good luck,
Sep 14, 2013 | Computers & Internet
When I turn on the computer it says boot mgr is missing. I guess I totally messed up when I tried to do a full system recovery. The discs I have are from geek squad there is tow of them.
An operating system would have been nice ?
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 24, 2012 | eMachines ET1810-01 PC Desktop
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
How do i fix error ofoo:0244 and ofoo:1a44 (msg block 16867582, 46028639 & 111595250), please? I get these codes when I start my pc
I would suggest you first try the Start Up Repair for Windows XP.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.
2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.
3. When you see the blue screen, let the computer load everything and when it's done choose "To set up Windows XP now, press ENTER"4. Press F8 to agree to the License Agreement 5. Choose "To repair the selected Windows XP installation, press R"
Windows will then start the repair process. Do not worry all your data and settings will be retained.
If above solution does not work then,Use Recovery Console.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.3. When you see the blue screen, let the computer load everything and when it's done press R to repair Windows XP using Recovery Console4. On the Recovery Console, choose the installation you would like to log on to (for example c:\Windows)5. Type Chkdsk /p /r on the Recovery Console and your computer will begin to check the hard drive for error and recover data.6. Once Chkdsk is completed, type exit then press Enter. Computer should restart. No need to boot from CD at this point. You can take out the Windows installation CD.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Microsoft Windows XP Home Edition
When I power the computer on, I'm getting an error message that says, windows could not complete the installation. To install windows, please complete installation and restart computer. How can I fix...
    • If the computer has a single operating system installed, press and hold the F8 key as the computer restarts. You must press the F8 key before the Windows logo appears. If the Windows logo appears, you must restart and try again.
    1. In Advanced Boot Options, use the arrow keys to select Repair the computer, and then press ENTER. Click a keyboard layout in the list, and then click Next. Click a user name in the list, enter the password, and then click OK. In the System Recovery Options menu, click Startup Repair. When the repair process is complete, click Finish.
    2. Hope this works!
    Jul 04, 2011 | Computers & Internet
    How do i reboot toshiba without the cd
    Hello, please follow the step,
    Toshiba System Restore Vista Step 1 - "Initiating the HDD recovery procedure"
    1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.
    Choose the entry "Repair your Computer" and press "Enter":
    2. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and click on "Next".
    If unsure, just click on "Next".
    3. the following screen a window with your username appears.
    Type your windows password as you would log on to your account and press "OK":
    4. The next screen offers several options to repair or diagnose your computer system.
    To start the recovery, click on "Toshiba HDD Recovery":
    Step 2 - Performing the HDD recovery
    1. After passing the previous screen, you will be asked if a backup of your important data is already made.
    You can continue with the recovery process by clicking on "Next"
    2. Confirm the following screen also by clicking on "Next"
    3. You will be asked again if you want to recover your machine (and delete all files on your harddrive).
    There are no additional options regarding the harddrive, which can be set. Click on "Yes" to start the recovery.
    4. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
    5. By pressing the "Restart" button to restart the machine, the recovery procedure is almost finished
    Step 3 - Finishing the recovery process
    1. After the successful completion of the recovery process and the restart of your machine, the following screen should appear.
    2. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly installed system and to finish the installation of the operating system
    FOR WIN 7 Toshiba System Restore Windows 7
    How to recover a Toshiba with the HDD recovery procedure
    - Operating System: Windows 7 - 32 Bit, Windows 7 - 64 Bit, Windows Vista 32 Bit, Windows Vista 64
    Bit
    The following guide describes how to recover a Toshiba with a preinstalled Windows windows 7 from HDD through the
    "HDD recovery procedure".
    Please note:
    First of all, make sure you already back up your important data!
    1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.Choose the
    1. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and
    click on "Next".
    1. In the following screen a window with your username appears.
    1. The next screen offers several options to repair or diagnose your computer system.To start the recovery, click on
    1. After passing the previous screen, you will be asked if a backup of your important data is already made.You can
    1. Confirm the following screen also by clicking on "Next"
    1. You will be asked again if you want to recover your machine (and delete all files on your harddrive).There are no
    1. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
    appear.
    1. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly
    Hope this helps,
    Hope this helps,
    Jan 25, 2011 | Toshiba Computers & Internet
    I did recovery manager. When it restart den it says ((The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click ''OK'' to...
    The previous windows installation is either damaged, or did not complete, it is asking you to put your windows disc in so that in can proceed with the installation.
    The recovery manager must have damaged your windows installation
    Sep 05, 2010 | HP Pavilion dv6000z Notebook
    My netbook says "Operating System Not Found" every time I turn it on.
    What were you doing prior to this error message ?
    Did you try to install another OS or During installation did you abort the process
    A clean installation of windows will resolve the issue
    Or Try this
    If you were able to start the computer prior to the issue, then try startup repair and check the result. To do this, try these steps.
    Step 1: Perform startup repair using Vista DVD
    a. Insert the Windows DVD.
    b. Restart your computer.
    c. Let the computer restart (boot) from the DVD.
    d. If prompted, press any key to continue.
    e. When you reach the Install Windows screen, select your preferences in the Language to install, Time and currency format, and Keyboard or input method boxes, and then click Next.
    f. Do not click Install now. Instead, click Repair your computer. The System Recovery Options dialog box appears.
    g. Make sure the correct operating system is selected, and then click Next.
    h. After you click Next, the System Recovery Options menu appears.
    i. Click Startup repair. Once the startup repair completes, click Finish to restart the computer.
    j. Remove the DVD and restart the computer to see if the system starts fine. See Make system repairs from the Windows Recovery Environment
    Also see http://support.microsoft.com/kb/932932 Go to BIOS (basic input/outputsystem (BIOS) and make hard disk as first bootable device. See BIOS: frequently asked questions
    http://windows.microsoft.com/en-US/windows7/BIOS-frequently-asked-questions Important: Modifying BIOS incorrectly will cause serious damage.
    Hope this helps
    Sep 05, 2010 | Dell Inspiron Mini 10v Netbook Computer
    After installing Windows 7 over Windows Vista, I attempted to restart my computer and instead of starting up Windows 7 my computer started up with Windows Vista, then it attempted to repair my computer by...
    you have to do clean a install of windows 7 ....if you want it as a secondary operating system. If you want to upgrade it from windows vista to ...so you have to do the install from the explorer.....I mean when you have booted to the windows vista....then insert the windows 7 dvd and do the install....
    this way you can tackle the problem
    Dec 30, 2009 | Computers & Internet
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
