Question about Garden
Murray 38608x92c electrical issues..the positive battery post becomes blistering hot after several unsuccessful attempts to start it. Could it be the starter or solenoid? I had to jump the mower with my truck to get it started
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 153 Answers
SOURCE: Ride on will not start. B&S motor.
Logic would dictate that the starter motor is burning out, drawing far too much current, and that the current overheated the solenoid and toasted it. Now the starter is almost a short circuit and while it spins it has no power. A spendy part to be sure. Perhaps you can find a used one from your friendly neighborhood repair guy.
A compression release is found on old diesel's, but not on gas engines.
Starters can fail from cranking on them for extended periods. They are designed to handle short periods of use, maybe 20 seconds on followed by several minutes (like 15) off. If you have had starting problems and kept cranking to get it going that would explain the fried starter.
Posted on May 14, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
woobie dog
  • 1273 Answers
SOURCE: Riding mower won't start from key switch
Do you have power to the switch? This is the only thing that jumps out at me, as you already did the right things.
Check that. I bet it'll get you going!
Regards, --W/D-- Feel free to rate my answer.
Posted on Jul 24, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
How do I fix an electrical problem with a 2000 chevy tracker
There are fusible links, usually located near the battery attached to the big red cable, or near the starter motor and again attached to the big main battery wire.
Oct 16, 2016 | Cars & Trucks
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Where can I find a Murray 12 HP 38 " lawnmower model 38608X92C manuel?
Murray can send you one some mower shops maybe able to print you one or part of it
Jul 26, 2014 | Murray Garden
2005 chrysler 300 key turns and it just clicks or does not do nothing
If you turn key to "RUN" position and your getting power to all accessories such as windows, radio wiper etc. then your most likely looking at a starter motor issue. When turning the key to "START" and you hear a slight click but keep turning it several times and it finally cranks over then the contacts inside the starter are not making good contact so as you continue to turn to the start position, it turns slightly until it gets good contact and finally spins the starter.
If your mechanically inclined you could take it apart and clean the contacts on the armature otherwise just cheaper to replace it.
Feb 11, 2013 | 2005 Chrysler 300
Need some spark in my life
Check your start fuse. Its a 20 or 30 amp. Just behind engine.
May 25, 2012 | Murray Garden
I have a 2000 jeep grand cherokee limited edition 4.7 liter V8 2wd. Recently it has just died whilst driving on the highway 40mph city driving. It just died quickly and all the gauges went dead like...
The first thing I would check is to make sure battery is securely tied down, cables are connected, and in good shape. Sounds basic but it has caused this problem for many of us.
- mark -
Apr 09, 2017 | 2000 Jeep Grand Cherokee
Check engine code 55 jeep grand cherokee laredo v6 1997. transmission wont shift properly also pulling code 21 and i figured out that one is for the throtle position sensor
These are the fault codes for your Jeep below;
Jeep
11 IGN reference signal.
13 Fault in the map sensor pneumatic circuit.
14 Fault in the map sensor electrical circuit.
15 Fault in the vehicle speed sensor circuit.
17 Engine running too cool.
21 Problem in the oxygen feedback circuit.
22 Fault in the coolant temperature sensor circuit.
23 Air temperature sensor.
24 Fault in the throttle position sensor circuit.
25 Fault in the IAC motor drive circuit.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
33 Fault in air conditioning cutout relay circuit.
34 S/C solenoid circuits.
35 Fault in fan relay circuit.
41 Fault in the charging system or no field current.
42 Fault in the ASD relay driver circuit.
43 Fault in ignition coil control circuit.
44 Battery Temp Voltage.
46 Battery voltage is too high.
47 Battery voltage is too low.
51 Lean condition is indicated.
52 Rich condition is indicated.
53 Internal problem in module.
54 Fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
76 Fuel pump resistor by-pass relay circuit
Mar 08, 2011 | 1997 Jeep Grand Cherokee
McCulloch M#FHH18A High Pressure Jet Washer,
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
May 29, 2009 | McCulloch FHH18A Electric Pressure Washer
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
