Question about Precision Series Various - Elko A Cowboys Gathering
Gathers audio WX-034C - Precision Series Various - Elko A Cowboys Gathering
I need a wiring diagram for a 1995 Honda Civic for my kdc-mp538u
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
May 18, 2014 | Kenwood KDC-MP538U Car CD/ MP3 Player
Loaction of reset button on sony wx-c570r cannot
the reset button is located just above and slightly left of the volume knob.it is very tiny,you will need a pin to depress it.
Mar 08, 2011 | Sony WX-C570R
Cobra 18 wx st, Rx & Tx is ok but no modulation
Hi, my name is John. Welcome to FixYa..Try a different mic., if that fail,s, we need to look at your audio chip, also a few capacitors..let me know , we are always here to help you. thanks for choosing FixYa...John
Nov 20, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Gathers audio WX-212M could you tell me how to set the time on the clock. the manual is all in japanese
hold the title (conf) button for one second. use the left / right skip bottons on the pad on the bottom right to select 'clock' then press 'ent' to confirm. Use the 1 and 2 buttons to adjust the hour and minutes, press 'ent' to confirm.
the website below helped me find the solution:
http://translate.google.co.uk/translate?hl=en&sl=ja&u=http://blogs.yahoo.co.jp/cyber205n/37315770.html&ei=i9ZcTYfsOYKosQOHxbnRCg&sa=X&oi=translate&ct=result&resnum=9&ved=0CFcQ7gEwCA&prev=/search%3Fq%3Dgathers%2Bwx-212m%26hl%3Den%26rlz%3D1I7ADSA_en%26prmd%3Divns
Oct 02, 2009 | Car Audio & Video
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Chevy Avalanche GPS makes constant sounds
This is the GM bulletin for your problem: 06-08-44-034C.
You need to have your truck compared to another of the same type. If yours is louder it should be replaced.
Aug 30, 2009 | 2009 Chevrolet Avalanche
No audio transmit or recieve adio chip 1A7217AP IC
it may not be that IC but maybe a electritic cap or a transister.
Jul 30, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 75 wx st
Hi and welcome to FixYa,
Initially, pls a couple of ideas you may want to consider/explore or try/check:
  • PA/CB switch must be to CB;
  • RF Gain max clockwise;
  • Squelch counter clockwise;
  • Volume to your desired level;
  • Mute (off);
  • external speaker/speaker connection;
  • audio amp, verify if there is TX modulation;
  • antenna, antenna cable. SWR should be low.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate this at all. Cheers.
Jan 01, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Wx stations disappeared
They did not put all the plugs back in from the weather board. Part of what has to be fiddled with is underneath the weather board.
Open the bottom cover where the speaker is, on the right side you will see a board separate from the main board. Look for any plugs unplugged. Its probably one that got over looked.
If there are no plugs out, who ever you took it too may have turned something they should not have. most likely its a plug. Its probably the plug that runs the audio into the radio from the weather board. its working, the audio just isn't getting to the rest of the radio.
there are about 3 or 4 plugs from the weather board to the main board of the radio.
Nov 10, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Precision Series Various - Elko A Cowboys Gathering Logo
Top Precision Series Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Precision Series Audio Player and Recorder Expert? Answer questions, earn points and help others
