Question about Baumatic 18 in. BFD46 Free-standing Dishwasher
Cycle will not start
My baumatic bfd46w dishwasher will not sart its cycle when the door is closed. The program dial remains in the same place when I set it to any particular wash. There is then a constant "whirring" sound but the machine does not fill with water and the program does not start. Please help
  • 19 Answers
Sounds like your machine is not taking in any water at all, which is the first thing the dishwasher wants to do on all programme settings.The constant whirring noise you refer to will be the water valve trying to take water into your machine.As yours isn't filling in the first place the programme cannot progress without water and it will just sit there whirring.Anyway, to resolve this matter I would check the fill hose which goes from the back of machine to your cold water pipe in your kitchen/utility, in case somebody has turned off supply.where the flexi hose meets the copper supply pipe there should be a thumbturn shut/open valve, turn this 90 degrees or a quarter turn and if you here a rush of water for a split second then you have fixed it.At this point try setting away a programme to see if water is going into dishwasher. If not have a bucket ready and unscrew the flexi hose altogether to make sure water is travelling past shut/open valve.If not you need a new shut/open valve.If water is able to pass this valve reconnect to dishwasher turn shut/open valve a quarter turn to open flow of water again,test machine on any programme again ,if it fills then your sorted, if not it must be your dishwashers internal water valve that will need replacing.Not a major job (located behind fill hose) but make sure electric and water supplies are off first before dabbling and write down your machines make and model number before shopping for part. GOOD LUCK.
Posted on Aug 15, 2007
SOURCE:
Samsung 7050 will dishwasher restart if opened in midcycle
if you have control dial or push buttons,1 set them for START 2 close the door and start normally
Apr 04, 2018 | Samsung Dishwashers
The programe wont stars
Dear Sir:
You must fit very well the door catch. The switch is the elements most important for to run the dishwasher. Otherwise you must waste your time.
See the diagram attached, and you will the switch door must be close for to close the starting relay for RUN the main motor.
sincerely. God bless you
May 04, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
Baumatic bdw45.1 integrated dishwasher
sorry i have no knowledge of this "baumatic" product line. please repost with another expert
Jan 28, 2009 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Nov 22, 2007 | Dishwashers
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Indeset d63 dishwasher
The heater is faulty Regards Engineer
Aug 17, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Baumatic 18 in. BFD46 Free-standing Dishwasher Logo
423 people viewed this question
Top Baumatic Dishwashers Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
