Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Need manual for MSNV-939 MB
By hickoryhi138 on Mar 14, 2009
I need the read out for the front panel controls!
Solution #1
posted on Mar 14, 2009
Not Rated)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1945 votes
Hi hickoryhi138,
The motherboard your referring to is made by Mach Speed.
Click on the link provided & scroll to the bottom of the link to download the manual; http://www.machspeed.com/specs/MSNVspecs.pdf
Drivers are also listed on the link.
For the manual (Only), click on the next link; http://www.machspeed.com/manuals/MSNV-939manual.pdf
Go to page 19, Header for Front Panel Facilities: JPANEL1
Knowing what wire color is positive & which is negative varies from case to case. Check the group of front panel wires. Most likely one wire from each 2-pin connector will share the same color. Like the color white which is common for ground/negative. Other colors, blue, green & red are commonly positive. The only exception is the speaker wires. Mach speed only uses two wires across four pins. Black is most common for ground & red is for positive.
Good luck hickoryhi138!
Thanks for using FixYa.
Need more information? Post here.
Mike
Don't forget to vote.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
kobp4m266andmxv7.3 mother board sound drivers, dispaly driver load my computer
Answer
dear sirs, i put wrong parameters in bios. so only beeps are result. cmos reset per jumper... (More)
Answer
when i plug my alltel wireless usb modem in the usb port,"motherboard is a jetway pm800... (More)
Answer
my vga connection is not working, when I turn on the computer the monitor goes into power save mode.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
