Question about Dometic Portable Ice Maker HZB-15S
Dometic Potable Ice maker HZB 15S
Makes ice, dumps ice, but will not recycle to fill tray with water. When it does fill with water it over flows, dramatically then will freeze cubes, dump them and not recycle to fill the tray???
3 Suggested Answers
  • 1796 Answers
SOURCE: I have a Dometic refrig.
Hi!!
Your problem could be a defective water dispenser valve. click on the following link for price and availability http://www.campingworld.com/shopping/item/dometic-new-dimensions-ndr1062-2-way-refrigerator-with-icemaker-double-door-10-cu-ft-/15999 .
I want to bring to your attention that there is a NHTSA 06E076000 Recall for your NDR 1062 in case you haven't been notified.
Defect Summary:CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003: SERIAL NOS. 713XXXXX THROUGH 752XXXXX; 801XXXXX THROUGH 852XXXXX; 901XXXXX THROUGH 952XXXXX; 001XXXXX THROUGH 052XXXXX; 101XXXXX THROUGH 152XXXXX; 201XXXXX THROUGH 252XXXXX; 301XXXXX THROUGH 319XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS AFTERMARKET EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence Summary:THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Corrective Summary:THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 13, 2010
luck_is
  • 5 Answers
SOURCE: Dometic ice maker is not filling with water. How should we troubleshoot problem
is water line connected, and turned on??? if so, check for a plugged filter, kinked supply line.
Posted on Jun 06, 2012
Where can I get replacement parts for ice maker
The link below will give you lead to a supplier. I don;t know anyone at this dealer but hopefully you will get the parts you need.
Dometic HZB 15S Portable Ice Maker 120 Volt RV Parts
Feb 19, 2015 | Dometic HZB-15S Portable Ice Maker Top...
Waterwell ice maker mod: HZB 15 error code " add water" even though tank is filled
Mine was having the same issue. The trouble-shooting section of the owner's manual mentions cleaning it but doesn't state where it is at. When I contacted Dometic they stated it is in the center of that circular hole in the bottom of the water resovoir, however, they couldn't tell me how to remove it.
Through trial and error, I found that it's just a little basket that fits snugly inside that hole. You DO NOT have to remove the round part that you can see. I used a pair of pliars in an attempt to remove the entire thing and the little basket (looks like a clear plastic thimble) came right out of the center. (If you have good hand strength you can likely just pull it out without using pliars.) I cleaned that off, placed it back into the ice maker and we are back in business. It is making ice as it should now.
Jan 13, 2013 | Dometic HZB-15S Portable Ice Maker Top...
Dometic Portable Ice Maker HZB-15S Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
