Question about Pioneer AVH-X7500BT Multimedia DVD Receiver APP Radio With Bluetooth
Pioneer error codes
What does error-02-DO mean?
What does code Soaoo indicate?
Search Results
    S0A00 Set-Top Box Error Message Help - Comcast
    customer.xfinity.com/help-and-support/cable.../getting-error-code-s0a00...
    Learn what S0A00 on your Comcast cable box means and how to resolve this ... A number of signs can tell you if your computer may be infected with a bot, ...Missing: pioneer
    ref code S0a00 - Comcast Help and Support Forums
    forums.xfinity.com/t5/XfinityTV-and.../ref-code-S0a00/td-p/855021
    Jan 18, 2011 - If you getting S0A00 errors, that means you have signal issues, most ...fios is cheaper than comcast, can you give an example of how fios is ...Missing: pioneer
    Comcast Ref Code S0a00 - How Do I Fix It? - GeekDrop
Jan 23, 2016 | Pioneer Televison & Video
AVH P3100. What does error code 02-9e indicate?
Error 02-9E Means there is a scratched or otherwise unreadable disc. The problem could be the laser as well. This error can mean any of the following:
Scratched disc
Improper media Bad burn/copy of disc
Improperly adjusted laser - requires an alignment
Dirty Laser Lens (smokers will experience this more often)
Laser failure etc.
Try changing the CD/DVD you are using and if you are still getting the same error, then try to visit you nearest Pioneer Service center and get your headunit's laser tested for allignment. How much you'd invest for repair must be below the cost of a new one or it's not worth it.
Nov 30, 2015 | Televison & Video
What does error code 02-19 mean on my pioneer stero system for the car?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 27, 2014 | Pioneer Audio Players & Recorders
Error code 02-d0 on my my pioneer 2500bt
I've heard replacing the USB extension cord will fix the problem. I'm trying that myself right after I get done typing this. A lot of people have had success with it.
Oct 28, 2013 | Audio Players & Recorders
Error code 02-66 when I try to use my ipod with my pioneer head unit
I fixed it! I had a working set up. I synced my iPod touch and update the software, then hooked it back upto my car stereo. I received error code 02-66. I disconnected the iPod and cable from the radio. Turned off the radio restarted the iPod. Turned radio back on with main menu displaying on iPod I hooked it back up to the Pioneer radio. Vuala! It works. Hope this helps.
Aug 09, 2013 | Car Audio & Video
ERROR CODES 15 and 12
http://audio.manualsonline.com/manuals/mfg/pioneer/deh-2800mp_2.html
May 05, 2009 | Pioneer DEH-2800MP CD Player
Error -02-09 on my avh-p5900dvd can you please help. thanks Eddie
02-xx error can mean a lot of things.
Here are some for you to try:
Dirty Disc -- clean disc
Scratched Disc -- replace disc
Disc loaded upside down -- make sure is going in correctly
Electrical or mechanical error -- press Reset
Hope this helps.
You might have to contact Pioneer if none of these work for you.
Apr 06, 2008 | Televison & Video
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Apr 03, 2008 | Car Audio & Video
Pioneer AVH-X7500BT Multimedia DVD Receiver APP Radio With Bluetooth Logo
272 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
