Question about John Deere Step 2510 2520 3010 3020 4000 4010 4020 Jd
John Deere 2520 ignition switch wiring
Wiring connection for ignition switch
wilsodfarm
  • 986 Answers
SOURCE: i need a diagram for the battery wiring on a 1969
They came out with 24
Posted on Jul 29, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
SOURCE: I would like a wiring diagram for a John Deere
I found the diagram.
Posted on Oct 20, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
Where dose hot wire go to from coils on la145 22hp v twin
the coil wire is only a kill wire. it goes through the wiring harness through safety switches back to the ignition switch.
Nov 10, 2016 | John Deere Garden
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
I need a sele oid wiring guide for a john deere z225.
25406829-sdtuz4uzlvmm4ye1kcvubb3h-5-2.jpg Basically the large wire from the battery goes to one of the larger threaded copper terminals and the large wire to the starter goes to the other [no particular order] The two small wires from the ignition and return via other interlock switches go to the two spade terminals [again, no particular order].
Feb 08, 2015 | John Deere 22 In. Rear Tire Chains
John deere wiring diagrams
these toys don't have ignition switches
Sep 03, 2014 | Peg Perego John Deere Farm Tractor and...
I need wiring diagram for 2007 john deere 2520
TM1004CD Parts NO for CD technical manual should have wiring diagram
Apr 02, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere 2520 wiring diagram
I did a quick Google for john Deere 2520 wiring diagram and multiple hits.
Dec 12, 2013 | John Deere Garden
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Step 2510 2520 3010 3020 4000 4010 4020 Jd Logo
129 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
