Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Kenmore side by side 22 ice maker
How do I stop the ice from sticking on the tray after dumping?
  • 2 more comments
  • Anonymous Jan 11, 2009
    my ice maker is only makeing half a tray of ice. Ive watched the tray fill and it seems to be getting good water flow. what could be wrong
  • Anonymous Mar 27, 2014
    ice maker has stopped dumping the ice. There is ice in the tray but it will not dump into the tray
    The ice maker has stopped dumping the ice. There is ice in the tray but it won't dump
  • 833 Answers
I'm assuming you're speaking of the mechanism that froze/transported the ice to the bin. Try a tiny bit of vegatable oil spray like Pam. If you are speaking about ice in the ice container, this is caused by a partial thaw of the ice...you're opening the door too often.
Posted on Jun 19, 2008
SOURCE:
Why doesn't my ice maker dump the ice out into the ice bin?
several reasons. 1) the ice level sensor bar is pushed up. 2) the motor may have accumulated ice inside it causing it to stop turning. 3) Ice tray thermostat may be bad not heating the tray just prior to dumping.
Aug 18, 2014 | Kenmore Refrigerators
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Why has It stopped making Ice
Is the ice maker getting water ?
Is the wire that senses that the ice tray has filled up down in the empty tray or up in the off position?
Is the freezer section cold enough to make ice ?
Is ice in the tray waiting to be dumped or water in the tray that is not freezing or is the tray dry ?
how can we answer when you give us no information.
Nov 26, 2010 | Kenmore 53092 / 53094 Side by Side...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side ice maker
in the freezer section where the front of the ice maker is a plastic face plate take that off and adjust the screw under neath it and ur problem can be solved
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not dumping ice
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
Icemaker slow to make ice
Tener, sounds like you have a module going bad. Pull off the white cover of the ice maker and take a look at the center white gear. There should be two clips securing the gear on. A lot of times these clips break and cause the gear not to rotate properly. Part number for the module is 628399. Take a look at this first. Catriver..post back
Nov 01, 2006 | Kenmore 53202 / 53204 / 53209 Side by Side...
Refrigerators Logo
1,346 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
