Question about Element Electronics FLX-2610 26 in. LCD HDTV
Code electronics element eldfw407
I have a eldfw407 model of element tv purchased in August of 2012 and the color is red in normal and in av and hdmi sources I cannot watch anything without red color. If I switch picture color temp to warm or cool the regular tv color works but in av and hdmi it remains red. How do I correct this problem my tv is not even a year old
    Top Expert:
  • Element Elec... Master
  • 75,178 Answers
HDMI white balance settings should be re-calibrated. It is a skilled work. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
  • 210 Answers
SOURCE: lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Posted on Dec 12, 2009
Testimonial: "Your response was quick pointed me in the right direction I might need help with ID of components to continue"
  • 40 Answers
SOURCE: element tv 32 in, sound work but no picture
Two bad capacitors in the power supply. 450v 10uf
Posted on Sep 28, 2010
raycalo
  • 358 Answers
SOURCE: i have an element 42" plasma, we were watching a
staceydesjar
Try unplugging the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After this, you should get your picture back. I hope this helps.
Ray Calo
DISH Network
Posted on Feb 02, 2011
  • 73 Answers
SOURCE: Hello, I cannot power on my Element Electronics
Unplug it leave it unplugged for about 10mins. replug it in and turn it on. If that doesnt work. Your going to most likely need to change the fuse for the power current. IF your not sure how to do this find expert repair services near you. It is cheaper to buy a new tv unless you try to do it yourself and end up damaging more
Posted on May 02, 2011
dduncan774
  • 760 Answers
SOURCE: Hi, my name is Johnny
Your TV has a bad panel. Your Panel needs replaced. Would be more cost effective to replace the TV.
Posted on May 19, 2011
Element eldfw407 has blue screen only does not get menu or input screenswhat would cause this
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 10, 2015 | Element Electronics 40 Class LCD HDTV -...
Code number
hi . you could try ge brand or philips brand universal remote control in code#1173 or auto code search. maybe working your element lcd tv. good luck!
Sep 03, 2012 | Element Electronics Televison & Video
I wanted to connect hp dv 4 1275 laptop with sanyo tv with hdmi and 3 rca .but its not working .tried everything din work.
You MUST install HDM IDrivers for your Video Card & MotherBoard. You can only use HDMI, OR Component, but NOT BOTH. Sometimes HDMI, requires an AUDIO OUT Cable, this is the Red & White, AV Stereo input.
OR you use COMPOSITE which is YELLOW, Video, now AUDIO, is Red & White.
COMPONENT, you use, Red, Blue, Green, (ALL VIDEO) PLUS you need the Stereo AV AUDIO too, Red & White.
HDMI, should supply BOTH, but as related sometimes you need the Audio red & White AV, inputs & Outputs.
ALL Cables go color to color.
h10025.www1.hp.com/ewfrf/wc/document?..
Resolving issues,with HDMI. above.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=us&os=2100&product=3860476
DRIVERS link above.
Apr 11, 2010 | Computers & Internet
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
How can i connect a x box360 to aproscantv lc
USE THE AV INPUTS SUPPLIED OR BUY THE COMPONENT CABLE THats the RED BLUE AN GREEN ONES OR THE HDMI ONES WHICH Are best then select the proper input mode
Dec 20, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
Jul 15, 2009 | JVC AV-56P575 56" Rear Projection...
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Element Electronics FLX-2610 26 in. LCD HDTV Logo
179 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
