Datacard cp80 plus
Ribbon break
rdiodoro363
  • 3 Answers
SOURCE: Hey, I have a datacard
I think you need to adjust the temperature by the driver.
Posted on Dec 20, 2008
  • 43 Answers
SOURCE: datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Posted on Nov 23, 2009
  • 36 Answers
SOURCE: Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Posted on Mar 19, 2010
  • 36 Answers
SOURCE: datacard SP 75 plus printer technical manual
contact tulsabiz.net
macminiguy
  • 34 Answers
SOURCE: The printer is not respondig.(DR-00901) in
If your looking for a new card printer...try www.getthatpart.com they have a few new in box Zebra HDP600 professional card printers if your interested.
Posted on Oct 25, 2010
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
The printer breaks the silver hologram ribbon everytime i print.it only break the silver ribbon when i do holograms
If your ribbon is breaking while printing a card, there area few things to look at.
  • Check that the printer driver has the appropriate ribbon selected. If a different ribbon is selected on the driver other than what you are using in the printer. Go into the driver and change the setting to the correct ribbon.
  • Another reason your ribbon may be breaking is because the "X" offset is set too low or too high, in other words the printing is beginning too close to the left side of the card, or ending too much to the right side so when the print head goes down to print on the card, the ribbon gets sliced because the print head and the edge of the card knife the ribbon. In order to eliminate this problem, increase or decrease the "X" offset value. I recommend a minimum of three digits up/down depending on the circumstance. For example: X-offset = 06...increase X-offset to 09. If the "X" offset is to high...EX: X-offset = 20...decrease X-offset to 17. Do not increase or decrease the value by more than 5.
  • If ribbon appears melted onto card, the print head may be damaged. Do not try adjusting. Immediately contact your re-seller or Zebra technical support.
  • If ribbon is breaking and nothing is being printed onthe card, contact your re-seller or Zebra technical support.
Dec 04, 2010 | Zebra P330i Thermal Card Printer
Ribbon breaks
Most likely a problem with the printer
Apr 10, 2010 | Sony SnapLab UP-CR10L Digital Photo...
RIBBON BREAKE
Several things can cause a ribbon to break. Let's start with the simplest - cleaning. Use your cleaning kit to clean the rollers and print head. If the rollers are dirty, cards can slip and cause ribbons to break. Another is the TOF setting. If the print image is too close to the front edge, the ribbon will break.
Check these 2 things and see if this helps!
onlineidtech
Feb 23, 2010 | Fargo DTC-300 Thermal Card Printer
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
3. Bad ribbon
Mar 27, 2009 | Datacard SP35 Printer
Broken ribbon on the Fargo Persona C30
Try a sensor calibration, its done through the printer drivers.
Jan 12, 2009 | Fargo Persona C30 Thermal Card Printer
Ribbon keeps breaking
It might be because the printhead is heating up too high, and burning the ribbon.
Try lowering the heat in the driver.
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Broken
See if there is a break in the ribbon cable.Place a light behind the ' ribbon ' so that you can see the the wires in the tape. If you see a break in the wire inside the ' ribbon ', you will have to ' jump ' the break with a wire soldered to each side of the break. You must strip ( vary carefully ) the plastic on EACH SIDE OF THE BREAK to reach the metel conduct. If you can, strip the plastic or melt it over the break and ' dap ' it with solder to reconnect the break.
Be careful because the ribbon with the electrical cable inside is very thin and fragil
Sep 01, 2008 | Panasonic DVD-LS90 Portable DVD Player
69 people viewed this question
k24674
jasbo
jasbo
