Carrier durakool my air conditioner get off again and again after few mintues . i think some energy saver option get activate or sleep mode please can u help me out how can i stop that option so it works regularly
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
early1234
  • 871 Answers
SOURCE: Heater and Air Conditioner
yes it does
check here... here
Posted on Apr 01, 2008
SOURCE: Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Posted on Aug 03, 2008
daddyo742001
  • 70 Answers
SOURCE: This goldstar air conditioner model is WG2405RY7
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Posted on Jun 30, 2009
relaga58
  • 158 Answers
SOURCE: air conditioner not working
have you tried turning off and on power from the plug ?
Posted on Aug 17, 2009
I have a window carrier ac 1.5 ton. display show 5A what is this
Its not 5A but SA means energy saver mode.use remote to change to cool mode without energy saver.
Sep 09, 2016 | Carrier Heating & Cooling
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
How do I turn off the sleep mode on my monitor?
Control panel Power options adjust time for monitor time to sleep you can adjust 5 minutes to never the option available same can be done for hard disk. This is necessary as even monitor is active and when hard disk goes to sleep you may end up in same situation
Alternatively you can activate screen saver by
right click on desktop, settings screen saver choose screen saver set time to activate screen saver.
Sep 03, 2011 | Computers & Internet
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
