Question about Dual XD7600 CD Player
Dual XD7600 Head Unit Problems
I have a Dual XD7600 Head unit. I've had it for less than a year. My problem is when I press to open the face plate. The motorized face just opens and closes and opens and closes nonstop. I have to hold the face closed and press the open button again to keep it closed. I can put cds in and pull them out just fine. I just can't open the face plate to see the Display. Any suggestions? Thanks, Henry
  • brucer07 Jan 13, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Posted on Aug 28, 2007
SOURCE:
I have a dual CD770 and every time i push the button to open the face plate,it wil start to open then immediatley close. how do i fix that? I own a 1997 Ford F150 Lariot EXT.CAB
You need to replace the ribbon cable that goes from location CN501 on the main board inside the unit to the face plate docking station. I have the had the same problem with mine for the last year and it finally broke. I just sent a quote request for the cable to dual.
Nov 07, 2010 | Dual Electronics XDVD700 Car DVD Player
How do you detach the face plate on a dual xd 7600 audio and how do u use the iplug?
tab at bottom of faceplate is visible when open in the middle of face push in carefully and pull down. supposed to be able to plug into it and comes up on screen.
Aug 17, 2010 | Dual XD7600 CD Player
Is the face detachable??... if so how?
there is a tab in the middle at the bottom of the faceplate. it has to be open in order to detach. pull down carefully.
Jun 18, 2010 | Dual XD7600 CD Player
My Dual XDM7615, will not even shut off and no buttons will work at all, it wont open or change stations and only plays radio on a station that sounds like AM,remote controll has new battery and wont even...
unplug the reciver from the back of it and wait for 20 sec. and plug it back in, this should allow you to eject. now turn off your car and jush eject, when it opens to eject's push the release button on the back of the face like your removing it but instead force the face to completely go down, as far as it will go. now turn your car on and put a cd in and see if that works for ya.
Jan 24, 2010 | Dual Car Audio & Video
Face plate removeal
Hello capthowdy148,
Here's the removal/installation procedure:
1) With the unit off, press OPEN to allow the front panel to slide
down.
2) Gently squeeze the release tab located on the bottom center underside and pull front panel down and away from unit to remove.
3) To install, insert left side first, then push right side to secure.
Hope this helps. If it does, please rate as "FixYa.
May 05, 2009 | Car Audio & Video
Won't Slide
try the small reset button on the face of the radio, it may reset it to original working condiion but other than that im outta ideas
Apr 20, 2009 | Dual XD-7500 CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
down. Gently squeeze the release tab located on the bottom
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
The face won't open
Can you pull the face out? If there is no sound at all coming from the head unit (besides the beep) there's a good chance the gear motor that controls the movement of the face is stuck or burnt. Now if there's a clicking sound, the gears may skipping which can be wear'n tear or misaligned gears. I wouldn't call you player done for though. I would take it out, inspect the motorized face machanism and post what you see.
Jul 26, 2007 | Dual XD7600 CD Player
Unit powers down when motorized face opens
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
Apr 11, 2007 | Pioneer DEH-P8500MP CD Player
Dual XD7600 CD Player Logo
523 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
