Question about Frigidaire GLEQ642A Electric Dryer
Frigidaire dryer a few minutes ago, my dryer decided it won't turn on! I've been using today and it was drying just fine....but pushing the start button now gives me nothing. If I put my ear down to the button and listen I can hear something barely buzzing, but I've checked everything, breakers, plug is fine, it's on the right setting, (I've tried several) and no turning on.....puzzling...it's about 8 years old...any ideas?
  • 2 more comments
  • sailorgal Aug 10, 2007
    but how do I fix it? Do I just pull out the little round cylinder button or what?
  • Anonymous Nov 17, 2007
    My Dryer was working great now it stopped I hear a buzzing noice when I turn it on and the light works, Now what?
  • Anonymous Aug 13, 2008
    My dryer stopped working suddenly. Now I hear a buzzing sound when I try to turn the "on" knob. Where can I find the number?
  • chasten Dec 07, 2008
    a few minutes ago, my dryer decided it won't turn on! I've been using today and it was drying just fine....but pushing the start button now gives me nothing. but I've checked everything, breakers, plug is fine, it's on the right setting, (I've tried several) and no turning on its about 6 yrs. old its a
    Frigidaire gallery
    model no. GLER341AS2
    serial no. XD31417323
There is a switch under the lid,Look for a slot onder where the lid rests on the dryer,there is an actuator under there where the dryer lid when shut should avtivate,this switch is either bent out of place,or the little pin that hits it when shut is missing or broke off.
Posted on Aug 07, 2007
SOURCE:
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
My 1999 Buick Park Ave started hesitating and the CEL would flash. I would back off the accelerator and it would smooth out and the light would go off. About a month ago the car died while I was driving it...
Have you tried the reset method? Turn key to the ON position and leave it there for 10 minutes, or until the security light goes off. Then turn key to off, and back to on and start-see if it starts after letting it sit for a few minutes like that with the key in the on position.
Apr 11, 2017 | 1999 Buick Park Avenue
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Nov 25, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore C11084 7029 0 dryer will not start
replace the main motor you have bad motor
Nov 12, 2007 | Dryers
Frigidaire GLEQ642A Electric Dryer Logo
136 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
