Question about Roland Versa Art RS 640 64-inch Printer
Roland printer error code 0040 - Roland Versa Art RS 640 64-inch Printer
What is error No. 0040
Your manual should have this information. If not you may be able find the manual on line.
Mar 18, 2015 | Roland SOLJET PRO III XJ-740
Motor error 0010
Estou com um erro na roland RS 640. Erro service call 0109!
May 20, 2013 | Roland Versa Art RS 640 64-inch Printer
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
Error code E061/0040
check and clean the Primary Charge unit or check all the door actuator check if there is damage .it couldbe the laser gate is not opening because the (door)actuator is broken
Jul 22, 2009 | Canon CLC-700 Copier
Error codes E020/04E0 and E061/0040
Clean the thermistors and the thermofuses the first copier,to second copier vacuum cleaning the suction fan ventilator and ozone filters.
Jul 22, 2009 | Canon CLC 1180 Copier
Service required error 0001002d
Feb 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Roland Versa Art RS 640 64-inch Printer Logo
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Ravi
Chas Peters
Level 1 Expert
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
