Question about HP DesignJet 500 InkJet Printer
Trouble connecting hp design jet to airport express w/ usb
I have connected my hp design jet plotter to my network via usb to my airport express. My mac recognizes the plotter, but only offers paper size selections of desktop printers, rather than the archD 24x36. Any ideas? Thanks.
3 Suggested Answers
SOURCE: Does HP laserjet 1020 work with Airport Express
I removed any printer configurations for this printer in both my pc and my mac (both usb and wireless). Then I restarted both computers and added the printer via usb again to each. At that point I went back to the extreme configuration and under the printers tab it was finally seeing Hewlett Packard Laserjet 1020. After that, adding via Bonjour went smoothly on both platforms.
Posted on Oct 18, 2008
  • 2666 Answers
SOURCE: MY HP 6310 works fine with my MacBook pro when
The full drivers are not installed on your Airport as you are acessing the printer via your MacBook in your network.
Posted on Sep 01, 2009
How do I connect hp deskjet f4280 to a wireless network?
Bluetooth wireless printing is not supported on this model - you could try a Cisco-Lynksys WUSB54G wireless-G USB adapter or a IOGEAR USB 2.0 Print Server, 1-Port GPSU21 both available on Amazon
Dec 23, 2014 | HP Office Equipment & Supplies
How can i install hp designjet 5500 PS on my com puter using network cable? My plotter (hp designjet 5500) do not have USB port instead it has netwok port from which one can install via the local network...
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Apr 15, 2011 | HP DesignJet 5500PS InkJet Printer
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
Aug 06, 2009 | HP DesignJet 1050c plus InkJet Printer
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
Mar 06, 2009 | Canon PIXMA MP610 InkJet Printer
Oct 17, 2008 | HP LaserJet 1020 Printer
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Network Connection (LAN) for HP 650C
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 500 InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
