Question about Campbell Hausfeld Air Tools & Compressors
Lr 59232-3 - Campbell Hausfeld Air Tools & Compressors
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I need a pressure switch for MDL# WL 506206 AJ It's a Condor LR 59232-3
Hi mark25338
If you do not want to retire your compressor just as of yet, then I recommend that you go to a place like Grainger (go to the link) and tell them what you have and what you need,They can help you figure out a replacement pressure switch for the compressor...it may take a little "jury rigging" but it will work with a different pressure switch...as all the pressure switch does is shut off and on with pressure.
Please take time to rate me
Bud
http://www.grainger.com/Grainger/wwg/start.shtml
Here is the page with the pressure switches.
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=pressure+switch+for+compressor&op=search&Ntt=pressure+switch+for+compressor&N=0&GlobalSearch=true&sst=subset
Posted on Oct 11, 2012
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
Dtc c1073
depends on the car im guessing that the chrysler one is the one ur looking forChrysler:ABS Pump Motor Control CircuitDodge:ABS Pump Motor Control CircuitJeep:ABS Pump Motor Control CircuitFord:LR ABS Valve coil short to ground.Mercury:LR ABS Valve coil short to ground.Lincoln:LR ABS Valve coil short to ground.Mazda:LR ABS Valve coil short to ground
Nov 18, 2012 | Mitsubishi Cars & Trucks
Hi mark25338
Bud
Oct 10, 2012 | Campbell Hausfeld Extreme Contractor...
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Nov 27, 2010 | Maytag Neptune Washer
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Air Tools & Compressors Logo
148 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
