Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1995 tahoe 1995 Chevy Tahoe 140k 5.7 liter 4x4 auto. The truck lopes on idle then cuts out you can floor it and it is like it cleans out. Will be fine for a bit then starts cutting out again. Put new fuel pump, fuel filter, throttle position sensor, egr valve, plugs,cap,rotor,wires, set timing, rebuilt throttle body with new injectors and rebuilt regulator. Put new catalytic converter on it too. New Radiator cap, new gas cap. Really getting frustrated. No check engine light on either.
    Problem Solver:
97 Tahoe.... I have a 96 Tahoe and had a similar problem. after much headaches like you and a lot of money one day I saw a drip of gas under truck.replaced a section of fuel line near the back drivers side.the problem was at idle it was sucking AIR into the system,but did not notice it as much going faster.
Posted on Dec 02, 2014
    Scholar:
  • 117 Answers
Does black smoke come out of the exhaust pipe when you floor it? Is so, it is running rich. Make sure fuel pressure is with in limits. A bad regulator may permit too much pressure. Also check the MAP sensor. Make sure it is getting vacuum.
Posted on Nov 02, 2013
SOURCE: 1997 chevy tahoe performance
try putting some of that fuel injector cleaner in your gas tank next time you fill up...and if you really want better mileage i have a 97 tahoe also and i put an airade cold air intake on it and its like night and day difference with mileage as long as you dont pound the petal...if you do decide to go fast it gives you like 10hp gain too and it'll take off a lot faster and sound sportier.
Posted on Nov 13, 2008
Danno5691
  • 17 Answers
SOURCE: engine dies after starting and running
I had a wiring harness that grounded out my computer on the exact same truck, fortunatly mine fell under warrenty. Fixed a bare spot in the harness, it was a hot wire feeding the computer.
Hope this helps.
Dan
Posted on Apr 25, 2009
SOURCE: 1997 chevy tahoe misses at 65 to 70 mph
chek your coil packs
Posted on May 07, 2009
  • 191 Answers
SOURCE: gas not spraying at throttle body
replace the injector - before you do that test voltage going to the injector- is should pulse on and off to open and close it
Posted on Aug 03, 2009
  • 18 Answers
SOURCE: 97 Chevy Truck starts and idles rough and then shuts down
Sounds like you're loading up with fuel. I'd check the fuel pressure regulator. Some engines are set up with a regulator inside the intake plenum, which requires plenum removal.
Posted on Oct 01, 2009
How much transmission fluid does a 2003 chevy tahoe hold?
here is the fluid capacity for your tahoe
Application
Specification
Metric
English
Pan Removal - Approximate Capacity
4.7 liters
5 quarts
Overhaul - Approximate Capacity
10.6 liters
11 quarts
Jun 09, 2011 | 2003 Chevrolet Tahoe
My heat only comes out the floor position. it is stuck it won't change to vent, defrost, etc. need help my wife needs clear window so she can see to drive in early cold winter morning with my daughter. ...
the first step is to look under the hood there is vacuum hose that goes into the inside of the truck make sure that is connected if you here a hissing sound that probably it
Nov 04, 2010 | 1995 Chevrolet Tahoe
I need to see the diagram of how the spark plug wires are attached to the distributor of a 1995 tahoe 5.7
1995 Chevrolet Tahoe 5.7 liter V-8 VIN "K"
Hope helps (remember comment and rated this).
Jul 27, 2010 | 1995 Chevrolet Tahoe
My 2001 tahoe dies while idling in park. After waiting over night it started and ran fine until allowed to idle in park for a short time. This a 2001 Chevy Tahoe with a 5.3 liter engine and 160,000 miles.
If the only problem is idle and it runs grat above ide then the most likely component is the Idle Air Control valve. This is providing you have no codes stored indicating something else.
Mar 13, 2010 | 2001 Chevrolet Tahoe
1995 chevrolet tahoe 4x4 posi rearend axel bearing replacement how do i remove the posi unit to get the axels out?
You don't. Ever work on a rear axle. Remove cover,one bolt,pull pin and axle clip.Then pull axle, and off to auto parts store, to press on new bearing.
Feb 13, 2010 | 1995 Chevrolet Tahoe
1995 chevy tahoe 2dr 5.7L 4x4 wont engage justs 4x4
go to the front axle and take the actaushwaiter out and gert a new one
Feb 13, 2010 | 1995 Chevrolet C/K 2500
1998 Chevy tahoe Hard to start when cold
replace your MAP sensor(manifold absolute pressure) the map sensor is the computer for your fuel pressure regulator telling how much pressure. Unless your tahoe runs like **** going up hill than it inevitably your fuel pump
Feb 17, 2009 | 1999 Chevrolet C/K 2500
1995 Chevy Tahoe 4x4 4dr 350
try it with no thermostat if its still the same only later then try changing the sensor unit.racking my one brain cell here had a problem like this on a seat ,and it was the fan cut in switch its first run it wouldnt cut in then afterwards it was fine all day ,thermostatic coupling switch is the technical term to you me its the switch in the radiator that puts the fan on.
Nov 13, 2008 | 1995 Chevrolet Tahoe
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
102 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
