Question about Sewing Machines
Elna 1250 which type of bobbin case do I use for an Elna 1250
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
  • 185 Answers
SOURCE: elna 1600
On a 1600 the bobbing case should not turn. the metal around it should. It should remain stationary.
The part thet turns is called the hook. Is the hook spinning. Is a new needle in the machine? That is where I would start.
Posted on Feb 19, 2008
SOURCE: Sewing Machine Elna 6000 model
Cannot get top thread to catch and uplift bobbin thread, have changed bottom bobbin; think this may be shuttle problem. Need to get machine in to Polokwane in Limpopo Province to a repair center, cannot find a contact number of Elna there. Can you assist?
Posted on May 27, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
Zenqi
  • 208 Answers
SOURCE: winding bobbin- elna
The bobbinwinder spindle is on the top of the machine on the right.
Try to turn the spindle with your fingers. If it is turning easily, good. If not, see below.
Push the spindle to the right and it should turn when the handwheel turns.
If the spindle does not turn properly, remove the two screws that hold the top cover on. DO NOT REMOVE THE SCREW THAT IS ON THE SMALL BLOCK NEXT TO THE BOBBINWINDER SPINDLE.
The top cover will not remove because of the handle. While lifting up the cover, peer under to make sure that there is a small rubber tire on the under side of the bobbinwinder spindle.
If the tire is there, place a small drop of oil on the spindle and turn it until it frees up. Try not to get oil on the tire, it will make it slip. Wipe it off if it gets oily.
Replace the top and retry.
Posted on Jul 26, 2009
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
How to tighten a loose bobbin case on an Elna 21C sewing machine?
The only thing to really tighten on a bobbin case is the tension screw. (Unless, what is really loose is the mechanism--hook, shuttle--that the bobbin case fits into.) It will probably be worthwhile to just bite the bullet and buy a new bobbin case for the machine. They aren't that expensive and it certainly will relieve a lot of potential future frustration.
Jan 06, 2016 | Elna Sewing Machines
Where can i buy bobbin case for elna sewing machine
from a service agent for elna
from e-bay--- in the search or want to buy section , type in bobbins for elna sewing machine
from elna on line spares department.
Sep 03, 2015 | Elna Sewing Machines
How can I reinsert bobbin race back into my elna su 68?
Hey I can help you with this, its a long detailed explanation though. Have you removed the bobbin holden, ie,undone two small screws and lifted out the silver bobbin case, leaving a black round thing? This black bit is the lower ring guard, you have probably undone this to remove a thread caught in the edge of the bobbin case or umderneath. Elna manuals never detailed cleaning here but it is simple enough and needs doing from time to time, i have seen big wads of felted threads and lint under guard rings when pulling apart machines. This video shows how to line up the lower guard ring, the outer casing and the bobbin case.
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
I always turn the flywheel until the opening of the lower casing is facing forward, then look at the black lower guard ring and turn it until the cut out bit is facing the front. Now look a the bobbin case, it has a couple of silver Beaks and these need to fit in between the stoppers on the outer case. You will know if lined up right as it just fits straight in, wiggle a bit left or right until its lined up. Those two silver screws have to marry up with the two holes in the lower guard ring.
Once aligned , tighten up the two screws until firm. There is a dark coloured screw too, leave it alone.
Hope,is helps, once youve done this a couple of times, its easy.
Sep 04, 2014 | Elna Sewing Machines
What is the correct way to wind and insert bobbin in elna machine?
You always wind the Elna 7 hole bobbin with the holes on top, and load it into the bobbin case the same way, this means when you draw the bottom thread off the bobbin, it will turn anticlockwise.
Apr 30, 2014 | Elna Sewing Machines
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
Bobbin case Elna 62c
Really you are very appreciated in your machine maintenance. If you wanted to Elna SU 62c machine bobbin case
please see the link :
http://www.ebay.com/bhp/elna-sewing-machine-bobbins .
Dec 29, 2013 | Elna Sewing Machines
What kind of bobbin goes in an elna super type 62c?
Elna Tavaro SA swiss made machines all take a 720100 bobbin, looks like this
Flat on the bottom and 7 holes on top and slightly dished. Dont use anything else. You can buy them aftermarket from www.sewingpartsonline.com or any Elna dealer and I have seen them in my local Spotlight in Australia.
Feb 18, 2012 | Elna Sewing Machines
I bought second handle elna sewing machine,but there is no bobinscase. I want to elna inside babbincase, where i get. I am living in dandenong.
What model Elna, is it a Swiss made machine? If so, they have a top loading bobbin and not a removable bobbin case. Bobbins are metal with holes on the top.
Elna also did budget models made in Japan such as the Elnita or Contessa and these were front loading removable bobbin cases.
Later model Elnas are still top loading but plastic bobbins and look similar to Janomes.
Check the plate on right side of machine for model number details and once identified you might be able to find a manual on line for it. Try www.sewingmanuals.com or one of the other sites below. There is also a few Ebay vendors who sell pdf copies of manuals.
You can buy swiss elna parts on several websites in the USA such as www.sewingpartsonline.com or www.sewusa.com but if you are in the Dandenongs in Victoria, Australia then you might want to try one of the dealers in your area from this page http://www.elna.com/en-au/dealers.php and see if they can help you out.
Apr 08, 2011 | Elna 2007 Mechanical Sewing Machine
How to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Jun 11, 2009 | Elna Sewing Machines
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
