Question about Locks & Locksmithing
Kaba 790 rfid
How to reprogram an common area door
How do i remove the chip from a expedtion key?
The RFID chip is not removable.
Start with a new cut key and reprogram the RFID to the car security.
Jan 17, 2014 | 1999 Ford Expedition
How to extend or reprogram kaba machine expired date for authorised master key?
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
May 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When trying to reprogram a room key for entry, the initialization process works, but after you initialize and a green button appears, we connect the kaba to the door, but when we slide the card it says...
Contact Kaba Ilco directly with your problem.
Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331.
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Jan 22, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
A lockout occured on my kaba 1000 series lock (I suspect the dead latch has slip[ped into the strike plate. I need to open the door, what can I do?
if your think the deadlatch has slipped into the strike plate ( which is a very common problem ) -- when you press in the code on the lock - push or pull the door ( depending on in-swing or out-swing ) and try and relieve the pressure on the strike. as soon as the door is open adjust the strike so this does not happen again. if there is no room for strike adjustment you can get and install small door bumpers on the door jam to keep the latch from going to far.
c...
Jan 19, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I changed my combination and dont know what i set it to
If you forgot the combo you will need to reprogram it. If you can not get in to open the door to reprogram you can email llco at info@lilocksmith.com for an override code.
Good Luck
Dec 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do we reset the door code
From this page you can download the manual necessary to reprogram your 2000 series:
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14&obj=2000
You have two choices when you mouse over "manual" for the 2000. Each is a PDF file: you can download Adobe Reader from the link on the same page.
Dec 28, 2010 | Simplex Kaba E-Plex 2000 series Keyless...
I have forgotten the code for my code lock which is on my bedroom door.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
aspx?id=13
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to removed from door to change door slab?
Oct 06, 2010 | Simplex Kaba Ilco Unican LP1000...
Locks & Locksmithing Logo
101 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
